10-13-2008 06:50 PM - edited 03-03-2019 11:54 PM
I have 3 mb down and 1mg up internet connection I want to distribute the bandwith between 2 networks first 1 mb 512 k up and the second 2mb down 512 k up
is there a cisco hardware product to do so ??
10-13-2008 09:08 PM
1.Is this a DSL link, as it is supporting asymmetric speed ??
2.I will recommed you Ciso 1700 or 1800 series routers with HWIC on it to support 3 mb
HTH...rate if helpful..
10-14-2008 01:56 AM
well its not DSL its a 2 way (up/down)satellite link using an idirect receiver/transmiter!
10-14-2008 05:48 AM
Cisco routers that support QoS can effectively divide outbound bandwidth, but doing the same for inbound bandwidth isn't usually practical. The best for the latter is usage of a bandwidth management product. Don't believe Cisco has any, but there are a couple other vendors that do.
