2801 removes service-policy output from tunnel
dm
Hello!
I run 2801 with 124-24.T3 and I have following problem:
router is connected to internet over pppoe and ISP once per day breaks this link.
so I get:
Jun  7 19:31:56.639 MSK: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
Jun  7 19:31:56.663 MSK: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
and I also have tunnel interface which endpoint is accessible over internet.
so I get:
Jun  7 19:31:56.679 MSK: %ADJ-5-PARENT: Midchain parent maintenance for IP midchain out of Tunnel1 68844500 - looped chain attempting to stack
Jun  7 19:31:57.635 MSK: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
Jun  7 19:31:59.199 MSK: %TUN-5-RECURDOWN: Tunnel1 temporarily disabled due to recursive routing
this is not a problem, problem is that router when interface goes down removes service-policy output  from it, so I receive such message every day from runcid:
   ip ospf cost 1
   ip ospf mtu-ignore
   tunnel source Loopback1
   tunnel destination 192.168.200.199
-  service-policy output tunnel_mpr_gre
and have to restore policy manually.
Is there any way to tell router to not remove service policy.
   I'm not sure that why Qos was removed from the interface. However, your error indicated that the recursive routing occured because of 192.168.200.199 routed via Tunnel interface. You may try to solve this problem first.
HTH,
Toshi
