2811 Rommo1 mode
Cisco Freak
Level 4
Level 4
Hello Experts,
We have a Cisco 2811 Router which boots into the Rommon mode. Here is the related logs and configs:
System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
Copyright (c) 2005 by cisco Systems, Inc.
Initializing memory for ECC
c2811 processor with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Readonly ROMMON initialized
loadprog: error - on file open
boot: cannot load "flash:c2800nm-advipservicesk9-mz.124-13a.bin"
boot: cannot open "flash:"
boot: cannot determine first executable file name on device "flash:"
rommon 2 > dev
Devices in device table:
        id  name
    flash:  compact flash
bootflash:  boot flash
    eprom:  eprom
rommon 6 > set
PS1=rommon ! >
FE_PORT=0
WARM_REBOOT=FALSE
BOOT=flash:c2800nm-advipservicesk9-mz.124-13a.bin,12;
RET_2_RTS=02:13:14 Pacific Tue Apr 26 2011
BSI=0
RET_2_RCALTS=
RANDOM_NUM=365387326
?=0
I tried reseating the external flash card and rebooting the device, but no luck. Can anyone please help me to resolve this problem?
Leo Laohoo
The CF used is not "supported" by the router.
5 Replies 5
c2800nm-advipservicesk9-mz.124-13a.bin  is the only file you have on flash ?
how does 'show flash' looks like?
-If I helped you somehow, please, rate it as useful.-
Joseph W. Doherty
Could be bad hardware. Possibly a corrupt image.
Can you "see" the file while in ROMMOM mode? (Sorry, I don't recall the ROMMON commands to use to check.)
BTW, a 2811, with a later ROMMON software can also boot from USB.
Leo Laohoo
Does this mean that the Compact Flash might have gone bad?
No, it means the CF is not supported by the appliance.  Get a different brand of CF and try again.
And I doubt someone has upgraded the Bootstrap of the router so this means booting the IOS from the USB won't work.
