2811 router crashed
cciebrij70
Community Member
Hi there
seeing very strange behaviour of router router is connected to switch to provide analog when swich configured as trunk the router crash and reboot but when change to access its stable please advice me
sh flash:
-#- --length-- -----date/time------ path
1       202613 Jul 23 2012 13:10:52 crashinfo_20120723-131051-UTC
2       211635 Jul 23 2012 13:13:56 crashinfo_20120723-131355-UTC
3       199118 Jul 23 2012 13:17:00 crashinfo_20120723-131659-UTC
4       527849 May 10 2010 15:30:06 128MB.sdf
5       190206 Jul 23 2012 13:20:02 crashinfo_20120723-132002-UTC
6       192568 Jul 23 2012 13:23:06 crashinfo_20120723-132306-UTC
7       204070 Jul 23 2012 13:27:46 crashinfo_20120723-132745-UTC
8       208069 Jul 23 2012 13:30:48 crashinfo_20120723-133047-UTC
9       216530 Jul 23 2012 13:57:34 crashinfo_20120723-135733-UTC
10      186034 Jul 23 2012 14:00:40 crashinfo_20120723-140039-UTC
11      194990 Jul 23 2012 14:03:44 crashinfo_20120723-140343-UTC
12    53722384 Dec 02 2010 14:41:42 c2800nm-spservicesk9-mz.150-1.M3.bin
13      185843 Jul 23 2012 14:06:48 crashinfo_20120723-140647-UTC
14      189742 Jul 23 2012 14:12:20 crashinfo_20120723-141218-UTC
15      195812 Jul 23 2012 14:26:42 crashinfo_20120723-142642-UTC
16      202317 Jul 23 2012 14:29:48 crashinfo_20120723-142948-UTC
17      187677 Jul 23 2012 14:32:52 crashinfo_20120723-143252-UTC
18      186586 Jul 23 2012 14:35:54 crashinfo_20120723-143554-UTC
19      187983 Jul 23 2012 14:38:58 crashinfo_20120723-143857-UTC
20      185805 Jul 23 2012 14:42:00 crashinfo_20120723-144201-UTC
21      186139 Jul 23 2012 14:45:04 crashinfo_20120723-144504-UTC
22      199696 Jul 23 2012 14:48:08 crashinfo_20120723-144808-UTC
23      194965 Jul 23 2012 14:51:10 crashinfo_20120723-145109-UTC
24      206605 Jul 23 2012 14:54:12 crashinfo_20120723-145412-UTC
25      208469 Jul 23 2012 14:57:18 crashinfo_20120723-145717-UTC
26      218323 Jul 23 2012 15:06:22 crashinfo_20120723-150621-UTC
27      192526 Jul 23 2012 15:09:28 crashinfo_20120723-150927-UTC
28      205987 Jul 23 2012 15:12:30 crashinfo_20120723-151229-UTC
29      212546 Jul 23 2012 15:15:34 crashinfo_20120723-151533-UTC
30      203373 Jul 23 2012 15:18:38 crashinfo_20120723-151838-UTC
31      229716 Jul 23 2012 15:22:28 crashinfo_20120723-152227-UTC
32      213667 Jul 23 2012 16:31:10 crashinfo_20120723-163109-UTC
33      198445 Jul 23 2012 16:34:14 crashinfo_20120723-163413-UTC
34      185889 Jul 23 2012 16:37:16 crashinfo_20120723-163715-UTC
35      216353 Jul 23 2012 16:40:20 crashinfo_20120723-164020-UTC
36      220326 Jul 23 2012 16:43:24 crashinfo_20120723-164323-UTC
37      181415 Jul 23 2012 16:46:26 crashinfo_20120723-164625-UTC
38      224918 Jul 24 2012 08:36:18 crashinfo_20120724-083617-UTC
15 Replies 15
Giuseppe Larosa
Hello B Bhushan,
it is indeed a strange problem.
I would try the following:
a)
on the switch when setting the port to trunk mode add also
switchport nonegotiate
this would disable DTP on the port. The router does not understand DTP or VTP.but this usually does not lead to problems
also specify the list of permitted vlans with
switchport trunk allowed vlan x-y,z-k
This should avoid the router to be hit by broadcast, multicast or unknown unicast traffic coming from Vlans for which no subinterface is configured.  The list should include only the required Vlans corresponding to configured subinterfaces on the router.
b)
Another possible attempt to use a different IOS image on the router
It may be wise to open a TAC service request.
Edit:
I tried to perform a bug search with no results
Hope to help
Giuseppe
Please attach one of the latest crashinfo file here.
- Karthic
Leo Laohoo
Hmmmm ...
Your router is experiencing a crash-boot-loop.  It has crashed a few times, created the crashinfo file.  The flash has became full (no more space to create a new crashinfo file) and crashed again.
You may need to post the EARLIEST five crashinfo files.
cciebrij70
Community Member
thanks
all for relply I tried
Giuseppe suggestion
but router crashed as soon interface seen as trunk, attaching crashinfo please have a look
switchport trunk allowed vlan add 7,145,800
switchport mode trunk
1.  Remove all the network modules and HWIC cards;
2.  Eject the CF;
3. Using a media reader, delete some of the crashinfo files
4.  Insert the CF back to the router;
5.  Power up the router.
Hi Leolaohoo
what is CF, old device is in lab and its working fine, which failed on site
the issue is when device on site connected not able to change to trunk port bks causing router to reboot
BR
Bhushan
CF = Compact Flash card of the router.
this router is connected to switch and sw to VSAT to test I shut the VSAT interface and change sw to trunk
router stopped rebooting and I was able to ping to router and sw
I dont think its IOS issue could be VSAT causing router to reboot when its trunk
I don't think you understand.
The router is CRASHING.  Something is causing it to crash.  It's either an IOS bug, a faulty hardware or configuration error.  Anything.
Your last crashinfo file, called "38      224918 Jul 24 2012 08:36:18 crashinfo_20120724-083617-UTC" means the last crash occured on 0836 UTC, 24 July 2012.
Trunk or no-trunk, something is crashing the router.
updated IOS no joy, so removed all the configuration and started from  scratch noticed when used below command router crashed there is some  command which work with mgcp trunk can someone please advice
mgcp
mgcp call-agent XX.XX.XX service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0.7
mgcp bind media source-interface FastEthernet0/0.7
paolo bevilacqua
Update IOS.
Paolo
mgcp
mgcp sdp simple
Hi all
thanks for advice now router is fixed it was strange one I was sure there is no mem or IOS issue, i changed from on call manager to another and its working fine. router is stable tested all phones
Bhushan
