2811 SDSL
abillington
hello all,
I'm not seeing the G.SHDSL card installed in a 2811 router. The output is
WIC Slot 0:
Unknown WAN daughter card
WIC module not supported/disabled in this slot
Hardware Revision : 0.0
Top Assy. Part Number : 800-26571-02
Board Revision : A0
Deviation Number : 0
Fab Version : 01
PCB Serial Number : FOC10312NJH
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
The current IOS version:
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(3f), RELEASE
SOFTWARE (fc3)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 18-Aug-06 18:47 by alnguyen
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
KingstonRouter uptime is 42 minutes
System image file is "flash:c2800nm-ipbase-mz.124-3f.bin"
Can anyone advise what the issue may be? Apologies if its basic, I'm a switch person not a router one :-)
Thanks in advance
Andy
andy_at_optimip_dot_net
Martin Parry
Level 3
Level 3
Hi Andy
Please can you confirm the part code of the WIC? Are you trying to install the WIC-1SHDSL-V3. I know for this module that if you are running a 12.4 mainline image the minimum requirement is 12.4(3g), which would be one rebuild higher than your current release.
Please let me know.
Martin
hi Martin,
thanks for this will give it a go! Any other "gotchas" to be aware of? I'm unfortunately trying to configure it from the wrong (ie remote) end of an IP tunnelled console link so woudl prefer to make mistakes on this forum than on the router :)
Andy
