QoS configuration on Layer3 interface of Cat6500(IOS)
patrick.zhang
I want to config end-to-end QoS on my network. The only question left is that:
At the core layer, 2 Cat6500 connect to each other by layer 3 Gi interface with IP address, I don't know what's the difference between L2 and L3 interface QoS confiuration and how to do.
Can you please help to answer this question, thanks!
umedryk
Level 5
Level 5
Layer 3 IP precedence values?The IP version 4 specification defines the three most significant bits of the 1-byte Type of Service (ToS) field as IP precedence. IP precedence values range between zero for low priority and seven for high priority. Refer URL http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/12_1e/swconfig/qos.htm#wp1304725
