2821 BGP image
lcaruso
Level 6
Level 6
Which image is sufficient for just using a 2821 as a backup ISP router running BGP? I don't need all the voice stuff.
Thanks.
2 Accepted Solutions
John Blakley
IPBase supports BGP for that router.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
I don't have a link to compare difference, but the feature navigator link is here:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
You can select the features that you want, and it will give you the different versions of software that will support it. For example, if you were to select BGP, it should show you things like "IP Base", "Advanced IP Services", "Advanced Enterprise Services", etc.
HTH,
John
John Blakley
HTH,
John
Thanks John. By any chance, can you pass along the link that describes image differences for the 2821s.
HTH,
John
