2821 Router with unknown username and password
rawhite0636
Ok, I have a 2821 router that has a username and password. I thought I knew what they were, but apparently not. I even get prompted for them in Rommon.
Amit Singh
You can do a password recovery on the ISR.
Please use the link below for the procedure.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_password_recovery09186a0080094675.shtml
HTH,Please rate if it does.
-amit singh
I get to step 4 of this proceedure and I get the username and password prompt again. It never gets into ROMMON, so I can not input the commands in step 5.
There is either one of 2 issues:
1. Either you are not able to do a break, and accordingly please check this doc:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080174a34.shtml
2. Service password-recovery is disabled, and if thus please check the following doc:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5413/products_feature_guide09186a00802a1e76.html#wp1027258
HTH,
Mohammed Mahmoud.
