2851 IOS upgrade
rajeshk200_2
It looks easy by sound of it, but I have really no clue why it's happening
This is what I have done to upgrade the ios image.
2851-Router#delete flash:c2800nm-advipservicesk9-mz.124-9.T7.bin
Delete filename [c2800nm-advipservicesk9-mz.124-9.T7.bin]?
Delete flash:c2800nm-advipservicesk9-mz.124-9.T7.bin? [confirm]
2851-Router#
2851-Router#
2851-Router#sh flash
No files on device
64016384 bytes available (0 bytes used)
2851-Router#
2851-Router#
2851-Router#
2851-Router#copy tftp flash:
Address or name of remote host []? 10.32.0.45
Source filename []? c2800nm-advipservicesk9-mz.124-15.T7.bin
Destination filename [c2800nm-advipservicesk9-mz.124-15.T7.bin]?
Accessing tftp://10.32.0.45/c2800nm-advipservicesk9-mz.124-15.T7.bin...
Loading c2800nm-advipservicesk9-mz.124-15.T7.bin from 10.32.0.45 (via GigabitEthernet0/0): !!!!!!!!!!!!!!!!!!!!O!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 51278046 bytes]
51278046 bytes copied in 629.224 secs (81494 bytes/sec)
2851-Router#sh run
2851-Router#sh running-config | in boot
boot-start-marker
boot-end-marker
-#- --length-- -----date/time------ path
1 51278046 Nov 19 2008 10:39:34 +00:00 c2800nm-advipservicesk9-mz.124-15.T7.bin
12734464 bytes available (51281920 bytes used)
2851-Router#reload
Proceed with reload? [confirm]
Nov 19 10:40:41.677: %SYS-5-RELOAD: Reload requested by kannanr on console. Reload Reason: Reload Command.
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
Initializing memory for ECC
c2851 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
loadprog: error - on read during ELF program load
requested 51254000 (0x30e12f0) bytes, got 51253588 (0x30e1154)
boot: cannot load "flash:"
rommon 1 >
I really need to your inputs to get this done and your help much appreciated.
Cheers,
Rajesh
jpoplawski
Were you able to see if the image is on flash within ROMMON? What happens if you type Boot at the ROMMON prompt?
durga_suji
Rajesh,
You can do the following:
1. after the image is downloaded to flash do #verify flash:c2800nm-advipservicesk9-mz.124-15.T7.bin
2. Go to config mode and #boot system flash
3. wri mem
4. Reload..
If this does not work, then re-download the IOS image from cisco website or try loading another image. may be the image was corrupt.
regards
srinath
viyuan700
Level 5
Level 5
try
reset at ROMMON if that doesnot work see if u have IOS image.
You can try to copy IOS once again from ROMMON through hyperterminal if booting from earlier file doesnot solve your problem.
