2900 router can't ping new workstation from all interfaces
tnshurtm1
We have a 2900 router that acts as DHCP server and can not ping a new workstation that is not DHCP.  I can ping the new workstation from the 10.45.4.1 interface, but not from any other.  I can ping existing workstations from all interfaces.  Is it some access list that is only allowing for DHCP addresses to be pingable?  There is some legacy stuff in the router (BGP) that isn't being used.  Here is the config:
Building configuration...
Current configuration : 22818 bytes
! Last configuration change at 15:58:47 EDT Fri Apr 25 2014 by
! NVRAM config last updated at 11:09:52 EDT Sat Apr 5 2014 by
version 15.1
service timestamps debug datetime localtime
hostname
boot-start-marker
boot-end-marker
logging buffered informational
no logging console
no aaa new-model
ida-client server url https://www.cisco.com//cgi-bin/front.x/ida/locator/locator.pl
clock timezone EDT -4 0
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.45.4.1 10.45.4.9
ip dhcp excluded-address 10.45.8.1 10.45.8.9
ip dhcp excluded-address 10.45.30.1 10.45.30.9
ip dhcp excluded-address 10.45.31.1 10.45.31.9
ip dhcp excluded-address 10.45.32.1 10.45.32.9
ip dhcp excluded-address 10.45.33.1 10.45.33.9
ip dhcp excluded-address 10.45.34.1 10.45.34.9
ip dhcp excluded-address 10.45.35.1 10.45.35.9
ip dhcp excluded-address 10.45.80.1 10.45.80.9
ip dhcp pool DataVLAN
 network 10.45.4.0 255.255.255.0
 default-router 10.45.4.1
 dns-server 10.44.80.249 10.44.80.252
 option 156 ascii ftpservers=10.44.8.2,country=1,language=1,layer2tagging= 1,vlanid=25
ip dhcp pool VoiceVLAN
 network 10.45.8.0 255.255.255.0
 default-router 10.45.8.1
 dns-server 10.44.80.249 10.44.80.241
ip dhcp pool Access-Points
 network 10.45.30.0 255.255.255.0
 default-router 10.45.30.1
 dns-server 10.1.0.10 192.168.254.204
ip dhcp pool Guest-Wireless
 network 10.45.31.0 255.255.255.0
 default-router 10.45.31.1
ip dhcp pool Staff-Wireless
 network 10.45.32.0 255.255.255.0
 default-router 10.45.32.1
ip dhcp pool Voice-Wireless
 network 10.45.33.0 255.255.255.0
 default-router 10.45.33.1
ip dhcp pool Mobile-Wireless
 network 10.45.34.0 255.255.255.0
 default-router 10.45.34.1
ip dhcp pool WAAS
 network 10.45.35.0 255.255.255.0
 default-router 10.45.35.1
ip dhcp pool New Server
 network 10.45.80.0 255.255.255.0
 default-router 10.45.80.1
ip dhcp pool voicevlan
ip flow-cache timeout active 1
ip domain lookup source-interface GigabitEthernet0/1.21
ip name-server 10.44.80.249
ip name-server 10.44.80.241
ip ips config location flash:ips retries 1
ip ips name IPS_1 list IPS_ACL
ip ips signature-category
  category all
   retired true
  category ios_ips basic
   retired false
ip ips auto-update
 occur-at weekly 0-6 50 0-23
 url https://www.cisco.com/cgi-bin/front.x/ida/locator/locator.pl
login on-failure log
login on-success log
password encryption aes
crypto pki trustpoint
 enrollment selfsigned
 subject-name
 revocation-check none
 rsakeypair
crypto pki trustpoint root
 enrollment terminal
crypto pki trustpoint rootVeriSub
 enrollment terminal
crypto pki certificate chain
 certificate self-signed 01
        quit
crypto pki certificate chain root
 certificate ca 01A
        quit
crypto pki certificate chain rootVeriSub
 certificate ca 07271446
        quit
license udi pid CISCO2911/K9 sn FTX1604F049
archive
 log config
  hidekeys
 path
 write-memory
username Orlansinfrastructure password 0
username rancid privilege 15 secret 5
username orlans2 privilege 15 secret 5
redundancy
crypto key pubkey-chain rsa
 named-key realm-cisco.pub signature
  key-string
  quit
no ip ftp passive
ip tftp source-interface GigabitEthernet0/1.21
ip ssh version 2
class-map match-any COS2-Video
 match ip dscp af41
 match protocol telnet
 match access-group name COS2-Video
class-map match-any bad-traffic
 match protocol bittorrent
 match protocol edonkey
 match protocol gnutella
 match protocol fasttrack
 match protocol kazaa2
 match protocol winmx
 match protocol directconnect
 match protocol gopher
class-map match-any voice-out
 match ip dscp ef
 match access-group name VOIP_TRAFFIC
class-map match-any sig-out
 match ip dscp cs3
class-map match-any AutoQoS-VoIP-Remark
 match ip dscp ef
 match ip dscp cs3
 match ip dscp af31
class-map match-any sig-in
 match ip dscp cs3  af31
 match ip precedence 3
 match ip precedence 4
class-map match-any voice-in
 match ip dscp cs5  ef
 match ip precedence 5
 match protocol skinny
 match protocol sip
class-map match-any AutoQoS-VoIP-Control-UnTrust
 match access-group name AutoQoS-VoIP-Control
class-map match-any COS5
 match ip dscp af11
 match access-group name COS5
class-map match-any COS4
 match ip dscp default
 match access-group name COS4
class-map match-any COS3
 match ip dscp af21
 match access-group name COS3
class-map match-any AutoQoS-VoIP-RTP-UnTrust
 match protocol rtp audio
 match access-group name AutoQoS-VoIP-RTCP
policy-map AutoQoS-Policy-UnTrust
 class AutoQoS-VoIP-RTP-UnTrust
  priority percent 70
  set dscp ef
 class AutoQoS-VoIP-Control-UnTrust
  bandwidth percent 5
  set dscp af31
 class AutoQoS-VoIP-Remark
  set dscp default
 class class-default
  fair-queue
policy-map QOS-MPLS-ISI
 class voice-out
  set ip dscp ef
  priority percent 40
 class sig-in
  bandwidth remaining percent 5
 class COS2-Video
  set ip dscp af41
  bandwidth remaining percent 30
 class COS2
  set ip dscp af31
 class COS3
  set ip dscp af21
  bandwidth remaining percent 15
 class COS4
  set ip dscp default
  bandwidth remaining percent 4
 class COS5
  set ip dscp af11
 class bad-traffic
  drop
policy-map VOICE-INBOUND
 class voice-in
  set ip dscp ef
 class sig-in
  set ip dscp cs3
policy-map VOICE-OUTBOUND
 class voice-out
  priority percent 55
 class sig-out
  bandwidth percent 5
crypto isakmp policy 1
 encr 3des
 authentication pre-share
 group 2
crypto isakmp keepalive 10
crypto ipsec transform-set esp-aes esp-sha-hmac
 mode transport
crypto ipsec transform-set esp-3des esp-sha-hmac
crypto ipsec profile
 set transform-set
crypto map SDM_CMAP_1 1 ipsec-isakmp
 description Tunnel
 set peer
 set transform-set ESP-3DES-SHA
 match address 100
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description ****connection to
 ip address 255.255.255.248
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/1.20
 description
 encapsulation dot1Q 20
 ip address 10.45.0.1 255.255.255.0
 description ***USER VLAN ****
 encapsulation dot1Q 21
 ip address 10.45.4.1 255.255.255.0
 ip flow ingress
 ip flow egress
 ip nat inside
interface GigabitEthernet0/1.25
 encapsulation dot1Q 25
 ip address 10.45.8.1 255.255.255.0
 ip flow ingress
 ip flow egress
interface GigabitEthernet0/2
 description EPL$ES_LAN$
 ip address 172.17.1.2 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
router eigrp 100
 network 10.45.0.0 0.0.0.255
 network 10.45.4.0 0.0.0.255
 network 10.45.8.0 0.0.0.255
 network 10.45.30.0 0.0.0.255
 network 10.45.31.0 0.0.0.255
 network 10.45.32.0 0.0.0.255
 network 10.45.33.0 0.0.0.255
 network 10.45.34.0 0.0.0.255
 network 10.45.35.0 0.0.0.255
 network 10.45.80.0 0.0.0.255
 network 172.16.38.0 0.0.0.255
 distance eigrp 201 201
 passive-interface default
 no passive-interface Tunnel2
router eigrp 101
 network 172.16.39.0 0.0.0.255
 distance eigrp 200 200
 no passive-interface Tunnel1
router bgp 65011
 bgp router-id 66.251.39.122
 bgp log-neighbor-changes
 network 10.45.0.0 mask 255.255.255.0
 network 10.45.4.0 mask 255.255.255.0
 network 10.45.8.0 mask 255.255.255.0
 network 10.45.30.0 mask 255.255.255.0
 network 10.45.31.0 mask 255.255.255.0
 network 10.45.32.0 mask 255.255.255.0
 network 10.45.33.0 mask 255.255.255.0
 neighbor remote-as 15270
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip flow-export source GigabitEthernet0/1.20
ip flow-export version 5
ip flow-export destination 10.44.80.251 9996
ip nat inside source route-map NATLIST interface GigabitEthernet0/0 overload
ip nat inside source static 10.44.80.250
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip route 10.44.0.0 255.255.255.0 172.17.1.1
ip route 10.44.4.0 255.255.255.0 172.17.1.1
ip route 10.44.8.0 255.255.255.0 172.17.1.1
ip route 10.44.31.0 255.255.255.0 172.17.1.1
ip route 10.44.32.0 255.255.255.0 172.17.1.1
ip route 10.44.80.0 255.255.255.0 172.17.1.1
ip route 10.44.100.0 255.255.255.0 172.17.1.1
ip route 192.168.1.0 255.255.255.0 172.17.1.1
ip access-list standard SNMP_ACCESS
 permit 10.44.80.251
 deny   any
ip access-list extended AutoQoS-VoIP-Control
 permit tcp any any eq 1720
 permit tcp any any range 11000 11999
 permit udp any any eq 2427
 permit tcp any any eq 2428
 permit tcp any any range 2000 2002
 permit udp any any eq 1719
 permit udp any any eq 5060
ip access-list extended AutoQoS-VoIP-RTCP
 permit udp any any range 16384 32767
ip access-list extended COS2-Video
 permit ip any host 10.44.80.235
 permit ip any host 10.44.80.236
ip access-list extended COS3
 remark COS3 - DSCP AF21
 permit tcp any any eq 389
 permit tcp any any eq 8471
ip access-list extended COS4
 remark COS4 - DSCP 0
 permit tcp any any eq www
 permit tcp any any eq 443
 permit tcp any any eq 143
 permit tcp any any eq 2525
 permit tcp any any eq smtp
 permit tcp any any eq pop3
 permit tcp any any eq 139
 permit tcp any any eq 445
 permit tcp any any eq 137
 permit tcp any any eq 8473
 permit tcp any any eq ftp
 permit tcp any any eq ftp-data
ip access-list extended COS5
 remark DEFAULT TRAFFIC
 permit ip any any
ip access-list extended INTERNET_FILTER
 permit tcp 10.0.0.0 0.0.0.255 any
 permit udp 10.0.0.0 0.0.0.255 any
 permit tcp 172.16.0.0 0.0.255.255 any
 permit udp 172.16.0.0 0.0.255.255 any
 permit tcp 192.168.0.0 0.0.255.255 any
 permit udp 192.168.0.0 0.0.255.255 any
 permit tcp any any established
 deny   ip any any
ip access-list extended IPS_ACL
 remark ACL Traffic to be scanned
 permit ip any any
ip access-list extended NAT_ACL
 remark CCP_ACL Category=18
 remark IPSec Rule
 deny   ip 10.45.4.0 0.0.0.255 10.44.0.0 0.0.255.255
 permit ip 10.45.4.0 0.0.0.255 any
 permit ip 10.45.31.0 0.0.0.255 any
 permit ip 10.45.32.0 0.0.0.255 any
 permit ip 10.45.34.0 0.0.0.255 any
 permit ip 10.45.80.0 0.0.0.255 any
 permit ip 10.45.0.0 0.0.0.255 any
 permit ip 10.44.4.0 0.0.0.255 any
 permit ip 10.44.80.0 0.0.0.255 any
 permit ip 172.17.1.0 0.0.0.255 any
 permit ip any any
logging 10.44.80.251
access-list 5 permit 10.44.8.235
access-list 5 permit 10.45.4.0 0.0.0.255
access-list 100 remark CCP_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 10.45.0.0 0.0.255.255 10.44.0.0 0.0.255.255
access-list 144 permit ip host 10.45.4.60 host 10.44.80.235
access-list 144 permit ip host 10.44.80.235 host 10.45.4.60
route-map NATLIST permit 10
 match ip address NAT_ACL
control-plane
banner exec ^CC
scheduler allocate 20000 1000
ntp server 10.44.0.1
end
6 Replies 6
tnshurtm1
The IP of the workstation in question is 10.45.4.9.  If I traceroute from something connected to G0/2, it gets to G0/2 and dies.
Wietse Hensen
Have you set a default gateway to your client? And have you set the right vlan to the switchport where the workstation is connected?
Yes.  The default gateway is set to G0/1.21 and the vlan is correct.  I can ping the workstation from the switch it is plugged into and from the G0/1 interface on the router.
Wietse Hensen
What happens when you change the settings of the workstation to dhcp? Have you tried changing the workstation to a different physical switchport?
Did not try different switchport.  Manually assigned an ip of 10.45.4.60 and it works fine.  Why won't it work with 10.45.4.9?  The device can not be set to DHCP.
Wietse Hensen
access-list 144 allows 10.45.4.60, but access-list is not connected to any interface on this router.
Can you try another ip-address. Not listed in any access-list. You can try to take an existing dhcp workstation set to a manual ip address. So you can decide the new workstation is the problem or the router.
