Showing results forĀ
Search instead forĀ
Did you mean:Ā
2900xl and 851w problems.....
dmbdata101
I am a newbie and I am studying for my CCNA Routing and Switching. I realize there are a lot of dumb  questions from newbies but that's how we all learn.
I have a 2900xl switch and a 851W router. I have both set up with addresses but cant seem to see my cable modem. I have a static ip from my cable company.  On the switch I have the following setup....
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname *************
enable secret 5 $1$Kmd9$mmQpNdevZhPU6dBJsSopt0
ip subnet-zero
no ip domain-lookup
interface FastEthernet0/1
 description INTERNET ROUTER CONNECTION
 duplex full
 speed 100
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
 port security max-mac-count 1
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
 duplex full
 speed 100
interface VLAN1
 ip address 192.168.0.40 255.255.255.0
 no ip directed-broadcast
 no ip route-cache
interface VLAN2
 ip address 192.168.2.10 255.255.255.0
 no ip route-cache
 shutdown
ip default-gateway 192.168.0.2
mac-address-table secure 3464.a9c9.0af8 FastEthernet0/20 vlan 1
banner motd ^CC
DO NOT LOG ON. This is a secure switch
^C
alias exec s show ip interface brief
alias exec siib show ip interface brief
alias exec src show running-config
alias exec ct config t
alias exec save copy run start
line con 0
 exec-timeout 60 0
 password cisco
 logging synchronous
 login
 transport input none
 stopbits 1
line vty 0
 password cisco
 logging synchronous
 login
line vty 1
 password cisco
 logging synchronous
 login
 ip netmask-format hexadecimal
line vty 2 4
 password cisco
 logging synchronous
 login
line vty 5 15
 login
end
My Router has the following running configuration...
Router#show running-config
Building configuration...
Current configuration : 2536 bytes
version 12.4
no service pad
boot-start-marker
boot-end-marker
enable secret 5 $1$t5eD$pr.pF.J5f//YvDSR9yyDB/
enable password cisco
no aaa new-model
dot11 ssid Cisco851W
   vlan 1
   wpa-psk ascii 0 cisco1234
dot11 ssid test1
no ip routing
no ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
archive
 log config
  hidekeys
bridge irb
 description USER 1
 no cdp enable
interface FastEthernet1
 description USER 2
 no cdp enable
interface FastEthernet2
 description USER 3
 no cdp enable
interface FastEthernet3
 description USER 4
 no cdp enable
interface FastEthernet4
 description INTERNET WAN PORT
 ip address 66.44.201.38 255.255.255.252
 no ip route-cache
 duplex auto
 speed auto
 no cdp enable
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption vlan 1 mode ciphers aes-ccm tkip
 ssid Cisco851W
 ssid test1
 speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
 station-role root
 no cdp enable
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Vlan1
 ip address 192.168.0.2 255.255.255.0
 no ip route-cache
 bridge-group 1
interface Vlan100
 no ip address
interface Vlan2
 no ip address
interface BVI1
 ip address dhcp
ip forward-protocol nd
no ip http server
no ip http secure-server
snmp-server community public RO
control-plane
banner motd ^C
This is a secure router. No unauthorized
logings are allowed per Admin.
^C
alias exec s show running-config
alias exec ip show ip interface brief
line con 0
 exec-timeout 120 0
 password cisco1
 logging synchronous
 login
 no modem enable
line aux 0
line vty 0 4
 exec-timeout 120 0
 password cisco1
 logging synchronous
 login
scheduler max-task-time 5000
no process cpu extended
no process cpu autoprofile hog
end
I dont mind showing my ip because its just for learning and I have nothing to hide (to poor, leary and broke lol)
I have a static ip of 66.44.201.38    255.255.255.252 from my cable company.
Network ip 66.44.201.36
Router ip 66.44.201.37
Broadcast 66.44.201.39
Any help is greatly appreciated and welcomed.
Dave
Gaurav Mahajan
Hi Dave,
help me understand if the issue is both switch and router cannot ping each other ?
if both switch and router can ping each other then you may need to do the following.
Can you help in understanding if you can ping 66.44.201.37 from your 851W router.
enable ip routing on 851W router.
add default static route on 851W router as
ip router 0.0.0.0 0.0.0.0 66.44.201.37
2nd you may require to configure NAT on the router to allow the users connected on switch to access internet.
