Multicast over GRE Tunnel: Sparse-mode problem
Bruno Silva
Hello friends,
i'm facing a unusual problem...
in my network i have a rendevouz-point and many sources which they're at same time subscribers between them. One, just one, of my subscribers is not a source, only receiver. The problem is, the connection between RP and that specific receiver i have established a GRE tunnel and the router (receiver) when join a group nevermore leaves the group.
Why??? have you have some ideas!? the big issue behind that is the excessive bandwidth consuming of GRE tunnel....
Thanks a lot...
Hello Bruno Silva,
When you mention "when join a group nevermore leaves the group", could you provide some outputs of what you are seeing?
Best Regards.
