2901 Router additional GBIC module & OSPF/HSRP query
avilt
Level 3
Level 3
Current Setup: Please refer the attached diagram.
Three 2901 series routers, no redundency for 172.16 segment, all running OSPF.
In order to provide redundency for 172.16 segment, I will add the HWIC-1GE-SFP with SFP module GLC-T on each router, will use only two routers for the enw setup.
My queries,
1. There are 4 expansion slots on 2901 router, which slot should I add the new HWIC-1GE-SFP?
2. With the new setup, is it alright to run OSPF on all interfaces? Or should I disable it on one segment on LAN side?
3. Any issues/eventualities with this setup?
Thank You,
Jon Marshall
Avilt
1) Any of them should support that HWIC card
2) Run it on both
3) No real issues. I'm assuming you have a L2 switch that interconnects the routers.
Jon
Just added the new module into the router and showing it as interface GigabitEthernet0/0/0
How can I hard code the speed amd duplex settings on this particular interface.
Is it thru negotiation auto?
I would like to set it to 100/Full instead of gbps. Is it possible?
