2901 Router Configuration
PATRICK_BRE
Does anyone see any issues with this base configuration. For some reason NAT seems to be only partially working. My LAN user can use a browser to search web sites. However when they click on a website link the browser will not pull down the pages. NAT must be working to a certain level or they would not even be able to bring up google and search site at all. Thanks for any sugestion.
hostname WFNR1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool LOCAL
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   dns-server 199.19.167.2 199.19.167.3
no ip ips deny-action ips-interface
interface Loopback0
no ip address
interface GigaBitEthernet0/0
description LOCAL INTERFACE
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface GigabitEthernet0/1
description WAN INTERFACE
ip address 199.19.166.162 255.255.255.252
ip nat outside
ip route-cache flow
no cdp enable
duplex auto
speed auto
interface Async1
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 199.19.166.161
no ip http server
no ip http secure-server
ip nat inside source list NAT interface GigaBitEthernet0/1 overload
ip access-list extended NAT
permit ip 10.10.10.0 0.0.0.255 any
control-plane
Raju Sekharan
This NAT configuration is enough for browsing to work
Check if there is some MTU issues or DNS resolution issues
You may need to sniff the packets to see what is going on
Raju
I should have mentioned that I have tried making adjustments with the mtu using a variety of sizes start at 1400 then incrementing 1410. 1420 1430 etc. Still no success. As far as DNS issues are you suggesting this could be an issue with the ISP. I have confirmed multiple time that these are the correct DNS values. Clients can ping the public address no problem and as stated they can perform google searches to find web sites however when the links are clicked they simple time out and not load. Can you suggest packet sniffer.
Finally though? As far as you can see is the config I am using look CORRECT?
many many many thanks
Hi Patrick
You have the right configs for NAT.
As mentioned eariler. if you sniff the packets for 1 or 2 minutes, it will help to narrow down the issue.
Raju
