Cisco 887VA-W Startup Wizard Missing
gareth.rooney
Ive just started up a new cisco 887va-w and the startup wizard doesnt start. Is there a way to make this manually start?
What i tend to do is run the wizard for the basic settings then run 10-15 lines from the client (depending on adsl or vdsl config) to configure the router.
But for some reason this one doesnt fire it after loging on with cisco cisco to 10.10.10.1 and changed the username and password. I just get the bebased cisco cp 'basic'. Cant see anyware on it to launch the wizard either.
Ive tried reset button on the back and reset to factory from cisco cp? any other ideas?
Software running on the unit is c800-universalk9-mz.spa.151-4,m4.bin
Gareth
dumesh
