2911 WebVPN
goldnetps
Hi team,
We are facing some issue on AnyConnect access, and we noticed that when we have multiple users, the connection attemps timeout.
I saw that I do not have any anyconnect licenses installed on this router.
What I want some help is to understand/confirm how many users can log in simultaneous with the default license security k9.
------------------------------------------------------------------------------------------------------------ show version:
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
SXSBRCOVPNBKP uptime is 7 weeks, 2 days, 21 hours, 28 minutes
System image file is "flash:/c2900-universalk9-mz.SPA.157-3.M8.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FTX1629ALRA
3 Gigabit Ethernet interfaces
1 terminal line
2 Channelized (E1 or T1)/PRI ports
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO2911/K9 FTX1629ALRA
Suite License Information for Module:'c2900'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
datak9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc uck9 Permanent uck9
data None None None
show license:
show license
Index 1 Feature: ipbasek9
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Index 2 Feature: securityk9
Index 3 Feature: uck9
Index 4 Feature: datak9
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
License Priority: None
Index 5 Feature: FoundationSuiteK9
Index 6 Feature: AdvUCSuiteK9
Index 7 Feature: ios-ips-update
Index 8 Feature: SNASw
Index 9 Feature: hseck9
Index 10 Feature: cme-srst
License Count: 0/0 (In-use/Violation)
Index 11 Feature: mgmt-plug-and-play
Index 12 Feature: mgmt-lifecycle
Index 13 Feature: mgmt-assurance
Index 14 Feature: mgmt-onplus
Index 15 Feature: mgmt-compliance
0 Replies 0
