2911 - Wireless Config
manoremaint
My company is about to purchase a Cisoc 2911 device for a network upgrade.
I see that the router doesn't come with wireless cards / anetenas; and wondering what are the alternatives to provide a LAN wireless network.
Would the configuration process for the wireless network will be the same (say 1811W)
Also, does anyone have expereince with the device's 3G module?  Is that a a relaible solution to count on as a backup for a failure in ISP E1 line?
Thank you,
Mor.
vmiller
Level 7
Level 7
NME-AIR-WLC6-K9 IP Base 2911 - 3945E 12.4(15)T
Maximum of 1 in supported
platforms.
Same for :NME-AIR-WLC12-K9 IP Base 2911 - 3945E 12.4(15)T
NME-AIR-WLC25-K9 IP Base 2911 - 3945E 12.4(15)T
I doubt the config process is the same. these are wilreless lan controllers.
No experience using the 3g as a backup.
Thank you.
I have been looking on that module; but they prices are way too expensive ( almost the price of the router).
Also, those are cards to manage multiple access-points; it doesn't come with wireless antenas. Please correct me if I wrong.
Did you have the chance to configure one of those?
Exactly! you are 100% correct.
I would delay any purchase until your requrements are better defined.
Good luck with that..
