2921 License what does ((( data datak9 None None ))) mean?
I've searched for an hour to try to find out what ((( data datak9 None None ))) means?  Sorry to ask such a silly question.  I'm afraid to test "disabling" licenses on my 2921s and there are some for sale that have this ((( data datak9 None None )))?????
Is the data license there but just now enabled, is it a question of IOS, or what?
that's more like it
this output means that
1) currently license active are ipbasek9, securityk9 and datak9
2) ipbasek9, securityk9 are permanent and will still be available after next reboot
3) datak9 is a temporary (evaluation) license and will be deactivated at next reboot
Technology    Technology-package   Technology-package
              Current              Type                 Next reboot
ipbase        ipbasek9             Permanent           ipbasek9
security      securityk9           Permanent           securityk9
uc            None                 None                None
6 Replies 6
pieterh
what command did you use to produce this text ?
my first assumption is that the "None None" part  means no expiry date and no count are used with this license
and datak9 means cryptographic options are enabled (SSL / VPN )
So I should be able to enable dataK9?  I can't run show license detail because I want to buy the 2921 it.  I just have never seen ((( data datak9 None None ))) before.
again:
what command did you use to produce this text ((( data datak9 None None )))  ?????
there must be some text around it that describes the columns.
if it is just some vendor information, then you need to ask the vendor.
It's not my router yet.  Here is the command from the little information that I can get.
Router#show version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.7(M3), RELE
ASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 19-Nov-14 01:53 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M1, RELEASE SOFTWARE (fc1)
Router uptime is 2 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.157-M3.bin"
Last reload type: Normal Reload
Last reload reason: power-on
Cisco CISCO2921/K9 (revision 1.0) with 503328K/40960K bytes of memory.
Processor board ID FCZ141971JD
3 Gigabit Ethernet interfaces
1 Serial interface
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*1        CISCO2921/K9          FCZ141971JD
Technology Package License Information for Module:'c2900'
uc                None                    None               None
Router# show inv
NAME: "CISCO2921/K9", DESCR: "CISCO2921/K9 chassis, Hw Serial#: FCZ141971JD,
Hw Revision: 1.0"
PID: CISCO2921/K9      , VID: V01 , SN: FCZ141971JD
NAME: "WAN Interface Card - HWIC CSU/DSU on Slot 0 SubSlot 0", DESCR: "WAN Inter
face Card - HWIC CSU/DSU"
PID: HWIC-1DSU-T1      , VID: V02 , SN: FOC163414P3
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC    , VID: V01 , SN: QCS1414H21W
that's more like it
uc            None                 None                None
Great Thanks, I can't imagine how I could not dig that up in Google searches. I appreciate your help.
