2921 Router Not Supporting SFP Transceiver.
anishlekshman
Dear Team,
I purchaised brand new router from Cisco 2921 also i purchaised an SFP-Transceiver (GLC-SX MM) along with this Router.
Currently the Router is having Universal IOS: “c2900-universalk9-mz.SPA.151-3.T1.bin”.
Kindly provide the IOS i woud like to use. Is the same is IOS Compactibility. thanks.
Leo Laohoo
config t
interface BLAH
media sfp
end
Dear Leo,
Thanks for your information. But the SFP itself not detecting in the Router. So how we will initiate this command.
Jose Solano
Level 4
Level 4
See this:
Problem solved.
MAJOR untested bug in IOS 15.0(1)M3 which was the default image when we bought the devices
*** AVOID IOS 15.0  series  ***
there are several bugs related to SFPs like:
does does recognize SFP
des not recognize some EHWIC cards such as, but not limited to EHWIC 1GE-SFP-CU
CSCtj35792
c3900 : gigE SFP should switch to 1000/FD if other side has no nego
Externally found severe (Sev2) bug: M-More
CSCth28824
c3945 GE shows DOWN/DOWN as compare to SFP
Externally found moderate (Sev3) bug: R-Resolved
They were fixed in 15.0(1)M4 or later
You can check the caveats for this IOS Release 15.0M:
http://www.cisco.com/en/US/docs/ios/15_0/release/notes/150MCAVS.html
Extracted from: https://supportforums.cisco.com/thread/2150674
Hope this helps.!!
