2921 Router Setup for Comcast Cable Modem - HELP!
dstriplin1
Hi All,
I'm leaning with my new Cisco 2921 router and I have a Comcast cable modem that sets the IP via DHCP from the ISP.  I have configured the router with what I thought would work, but I seem to be missing something.  When I connect my pc via ethernet, I get a valid IP address on the correct network, but I cannot get internet access.  Right now I'm just trying to get my router working, but once it works, I will connect it to a 3750 I have in my lab also, but for now, that is irrelevant.  Here is the basic topology of my lab network. Thanks in advance for your help!
ISP- Comcast Cable modem assigned IP via DHCP
Network 10.0.1.0/24
PC address - 10.0.1.22
Default GW - 10.0.1.1
Router Interfaces-
Gig0/0 - WAN from ISP
GIg0/1 - LAN (10.0.1.0/24)
Current Config that is running:
Lab2921#show running-config
Building configuration...
Current configuration : 2312 bytes
! Last configuration change at 13:00:16 UTC Tue Mar 26 2019
version 15.7
no parser cache
service timestamps debug uptime
service timestamps log uptime
hostname Lab2921
boot-start-marker
boot-end-marker
logging userinfo
enable secret 5 $1$aP02$GoblxTJ6F3.kaw7Soxvr50
no aaa new-model
ip dhcp excluded-address 10.0.1.1
ip dhcp excluded-address 10.0.1.2
ip dhcp excluded-address 10.0.1.177
ip dhcp excluded-address 10.0.1.169
ip dhcp excluded-address 10.0.1.100 10.0.1.254
ip dhcp excluded-address 10.0.1.1 10.0.1.5
ip dhcp pool InsideDHCP
network 10.0.1.0 255.255.255.0
default-router 10.0.1.1
dns-server 75.75.75.75 75.75.76.76
no ip domain lookup
ip cef
no ipv6 cef
vty-async
license udi pid CISCO2921/K9 sn FTX1728AHR1
redundancy
no cdp run
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Facing the ISP (the WAN)
ip address dhcp
ip nat inside
ip virtual-reassembly in
no ip route-cache
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/1
description Facing my LAN (the LAN)
ip address 10.0.1.1 255.255.255.0
ip nat outside
no ip route-cache cef
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source list 102 interface GigabitEthernet0/1 overload
access-list 1 permit 10.0.1.0 0.0.0.255
access-list 102 permit ip 10.0.1.0 0.0.0.255 any
control-plane
vstack
banner motd ^C
AUTHORIZED ACCESS ONLY
^C
line con 0
exec-timeout 0 0
password AlphaBravo9
login
stopbits 1
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
transport input none
scheduler max-task-time 5000
scheduler allocate 20000 1000
end
10 Replies 10
Mark Malone
External interface should be ip nat outside and the LAN ip nat inside to start get out to the internet
ip address dhcp
ip nat outside
Thanks for your help!  I have added the config line items that you stated, but I still have no internet access.  Here is the config after trying again...
! Last configuration change at 13:23:37 UTC Tue Mar 26 2019
version 15.7
no parser cache
hostname Lab2921
boot-start-marker
boot-end-marker
logging userinfo
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
vty-async
redundancy
no cdp run
no ip address
shutdown
ip address dhcp
ip nat inside
no ip route-cache
duplex auto
speed auto
no cdp enable
ip nat outside
duplex auto
speed auto
no cdp enable
no ip address
shutdown
duplex auto
speed auto
no ip http server
control-plane
vstack
banner motd ^C
^C
line con 0
exec-timeout 0 0
login
stopbits 1
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
end
Lab2921#show ip int
Embedded-Service-Engine0/0 is administratively down, line protocol is down
Internet protocol processing disabled
GigabitEthernet0/0 is up, line protocol is up
Internet address is 69.180.36.8/23
Broadcast address is 255.255.255.255
Address determined by DHCP
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is disabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP CEF switching is disabled
IP Null turbo vector
IP multicast fast switching is disabled
IP multicast distributed fast switching is disabled
IP route-cache flags are No CEF
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Policy routing is disabled
Network address translation is enabled, interface in domain inside
BGP Policy Mapping is disabled
Input features: Common Flow Table, Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, MCI Check
Output features: NAT Inside, Common Flow Table, Stateful Inspection, NAT ALG proxy
IPv4 WCCP Redirect outbound is disabled
IPv4 WCCP Redirect inbound is disabled
IPv4 WCCP Redirect exclude is disabled
GigabitEthernet0/1 is up, line protocol is up
Internet address is 10.0.1.1/24
Address determined by setup command
MTU is 1500 bytes
IP fast switching is enabled
IP multicast fast switching is enabled
IP route-cache flags are Fast, No CEF
Network address translation is enabled, interface in domain outside
Input features: Common Flow Table, Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, NAT Outside, MCI Check
Output features: Post-routing NAT Outside, Common Flow Table, Stateful Inspection, NAT ALG proxy
GigabitEthernet0/2 is administratively down, line protocol is down
NVI0 is up, line protocol is up
Internet address will be negotiated using IPCP
MTU is 1514 bytes
IP route-cache flags are Fast, CEF
Network address translation is disabled
Input features: MCI Check
Output features: Post-routing NAT NVI Output
the NAT statements still look the wrong way around ? or is that just the old conf shown ?
outside is always external interface , inside is always LAN side
what IP are you getting on the WAN is it a public IP address , is the midem in bridge mode to pull back the public IP address to the Cisco router or what way is that setup
Hi Mark,
The modem is the modem that comcast provides and assigns address via dhcp.  Right now I"m getting ip address 69.180.36.8 with dns entries of 75.75.75.75 , 75.75.76.76.  Here is the latest build so you can look, I thought I switched the NAT per your suggestion, but I might have made a mistake
Lab2921#show run
Current configuration : 2352 bytes
! Last configuration change at 14:01:42 UTC Tue Mar 26 2019
version 15.7
no parser cache
hostname Lab2921
boot-start-marker
boot-end-marker
logging userinfo
no aaa new-model
import all
class any
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
vty-async
redundancy
no cdp run
no ip address
shutdown
ip address dhcp
ip nat inside
no ip route-cache
duplex auto
speed auto
no cdp enable
ip nat outside
duplex auto
speed auto
no cdp enable
no ip address
shutdown
duplex auto
speed auto
ip http server
ip nat inside source list 102 interface GigabitEthernet0/0 overload
control-plane
vstack
banner motd ^C
^C
line con 0
exec-timeout 0 0
login
stopbits 1
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
end
Please make below changes:
import all
no dns-server 75.75.75.75 75.75.76.76
dns-server 8.8.8.8 8.8.4.4
class any
ip address dhcp
ip nat outside
no ip route-cache
duplex auto
speed auto
no cdp enable
ip nat inside
duplex auto
speed auto
no cdp enable
no ip nat inside source list 102 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
Must release and renew the IP on your PC.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
I did as requested, but still no internet access.....
Here is the sh run so you can take a look.  Thanks in advane!
Lab2921#show run
Current configuration : 2452 bytes
! Last configuration change at 15:06:44 UTC Tue Mar 26 2019
version 15.7
no parser cache
hostname Lab2921
boot-start-marker
boot-end-marker
logging userinfo
no aaa new-model
import all
class any
ip dhcp class any
no ip domain lookup
ip cef
no ipv6 cef
vty-async
redundancy
no cdp run
no ip address
shutdown
ip address dhcp
ip nat inside
no ip route-cache
duplex auto
speed auto
no cdp enable
bridge-group 59
bridge-group 59 spanning-disabled
ip nat outside
duplex auto
speed auto
no cdp enable
no ip address
shutdown
duplex auto
speed auto
ip default-gateway 10.0.1.1
no ip http server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
control-plane
vstack
banner motd ^C
^C
line con 0
exec-timeout 0 0
login
stopbits 1
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
end
I hope I am not adding anything redundant that has not already been said by Mark, but make sure the lines in bold match your confguration:
version 15.7
no parser cache
hostname Lab2921
boot-start-marker
boot-end-marker
logging userinfo
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
vty-async
redundancy
no cdp run
no ip address
shutdown
ip address dhcp
ip nat outside
no ip route-cache
duplex auto
speed auto
no cdp enable
ip nat inside
duplex auto
speed auto
no cdp enable
no ip address
shutdown
duplex auto
speed auto
no ip http server
--> no ip nat inside source list 102 interface GigabitEthernet0/1 overload
--> no access-list 102 permit ip 10.0.1.0 0.0.0.255 any
control-plane
vstack
banner motd ^C
^C
line con 0
exec-timeout 0 0
login
stopbits 1
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
exec-timeout 120 0
login local
length 0
end
Georg,
Thanks for the assistance.  I've changed the interfaces as described.  When I updated the config, I still don't have internet access.  Any thoughts?
Is the modem in bridge mode ?
what IP address is being assigned to interface GigabitEthernet0/0 by the modem ?
