02-15-2013 10:20 AM - edited 03-04-2019 07:02 PM
Hello, this should be something basic, but I can't figure out how to get around this issue. I have a 2921 router with 1 etherswitch module installed. I haven't done it before and was trying to change the baud rate to 115200 for installing an IOS on the etherswitch module which had been deleted. I ended up "unsetting" the baud rate on the etherswitch and rebooted. Now, when I try to session into the etherswitch, its opens the connection but I can no longer see any text on the screen. Im using Teraterm. I've tried different baud rate settings for my serial port in TeraTerm but still cant see any text on the screen. I dont know of any commands from the router prompt. Any suggestions to fix this? If can start seeing the text, then I can probably configure and set up the etherswitch module. Thank you! -Tim
03-01-2013 04:38 AM
Hello Tim,
Have you been able to correct this issue? If so, how? If not, can you at least try to get back to the 115200 speed and see if at least that helps?
Best regards,
Peter
06-21-2016 09:43 PM
Hello Tim.
This post is old but were you able to recover? Do you recall the steps taken to recover?
