2960 Privilege Mode Configuration
joseluis
I'm having problem configuring the privilege mode of the 2960 catalyst, every time i configure the command:
IOS: "flash:c2960-lanbase-mz.122-25.SEE2/c2960-lanbase-mz.122-25.SEE2.bin"
username test privilege 5 secret test
privilege exec level 5 show cdp neighbors
privilege exec level 5 show proc cpu
privilege exec level 5 show proc cpu history
privilege exec level 5 show proc mem sorted
privilege exec level 5 show proc cpu sorted
privilege exec level 5 show history
privilege exec level 5 show history all
privilege exec level 5 show log
privilege exec level 5 show redundancy
privilege exec level 5 show running-config
every time i login the username "test" and run the command "show run" i am only getting this result
SW#sh run
Building configuration...
Current configuration : 13 bytes
end
SW#sh run full
end
the only options are:
SW#sh run ?
brief      configuration without certificate data
full         full configuration
interface Show interface configuration
| Output modifiers
<cr>
What to config to view the full "show run" command
Thank you so much!
Francesco Molino
This is an expected behavior with show run and privileges.
Please take a look on this Cisco documentation that explains why:
http://www.cisco.com/c/en/us/support/docs/security-vpn/terminal-access-controller-access-control-system-tacacs-/23383-showrun.html
And here a discussion in there community regarding the same question:
https://supportforums.cisco.com/discussion/10813536/show-running-output-incomplete
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
