2960-X QOS Configure issue
I entered the following into a 2960-x;
mls qos srr-queue output dscp-map queue 1 threshold 1 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 2 threshold 1 8
mls qos srr-queue output dscp-map queue 1 threshold 1 9 10 11 12 13 14 15 16
mls qos srr-queue output dscp-map queue 1 threshold 1 17 18 19 20 21 22 23 24
mls qos srr-queue output dscp-map queue 1 threshold 1 25 26 27 28 29 30 31 32
mls qos srr-queue output dscp-map queue 1 threshold 1 33 34 35 36 37 38 39 40
mls qos srr-queue output dscp-map queue 1 threshold 1 41 42 43 44 45
mls qos srr-queue output dscp-map queue 3 threshold 1 46
mls qos srr-queue output dscp-map queue 1 threshold 1 47 48 49 50 51 52 53 54
mls qos srr-queue output dscp-map queue 1 threshold 1 55
mls qos srr-queue output dscp-map queue 4 threshold 1 56
mls qos srr-queue output dscp-map queue 1 threshold 1 57 58 59 60 61 62 63
after copying the running and startup config, show config had this output;
mls qos srr-queue output dscp-map queue 1 threshold 1 1 2 3 4 5 6 7 9
mls qos srr-queue output dscp-map queue 1 threshold 1 10 11 12 13 14 15 16 17
mls qos srr-queue output dscp-map queue 1 threshold 1 18 19 20 21 22 23 24 25
mls qos srr-queue output dscp-map queue 1 threshold 1 26 27 28 29 30 31 32 33
mls qos srr-queue output dscp-map queue 1 threshold 1 34 35 36 37 38 39 48 49
mls qos srr-queue output dscp-map queue 1 threshold 1 50 51 52 53 54 55 57 58
mls qos srr-queue output dscp-map queue 1 threshold 1 59 60 61 62 63
no mls qos rewrite ip dscp
mls qos
Is there a reason some of my entries didn't save?
How cna I delete them and re-enter all of them, or is there another way to fix this?
This config is to have DANTE running on the switch.
DANTE needs DSCP 8 on queue 2, DSCP 46 on queue 3 and DSCP 56 on queue 4.
How do these queues match IP priority?
Should I create a DHCP>COS map?
Please help
Bill
Joseph W. Doherty
The commands that didn't save might be defaults.
after you have entered the new values, and before saving the running to the startup config, does:
show mls qos maps
reflect the new values ?
