7200 router xmodem ios upload (urgent)
san_dec21
Hi,all
Pls help me urgentaly.
Can some one explain me how to upload ios image on cisco 7200 router using xmodem or tftp method
10 Replies 10
useless replies. Asked for 7200 vxr series routers and old easy 2600 series explained.
The steps to use tftpdnld are similar on many platforms. Just because the example suggested was for 2600 does not mean that it does not also apply to 7200.
Rick
What options do you have in ROMMON:
ROMmon: ?
ROMmon: boot ?
Thanks for your reply.
Option are
rommon 1 >?
alias set and display aliases command
boot boot up an external process
break set/show/clear the breakpoint
confreg configuration register utility
cont continue executing a downloaded image
context display the context of a loaded image
cpu_card_type display CPU card type
dev list the device table
dir list files in file system
dis disassemble instruction stream
frame print out a selected stack frame
help monitor builtin command help
history monitor command history
meminfo main memory information
repeat repeat a monitor command
reset system reset
set show all monitor variables
show_spd show all SPD data
stack produce a stack trace
sync write monitor environment to NVRAM
sysret print out info from last system return
unalias unset an alias
unset unset a monitor variable
rommon 2 >
As you noticed I cant do xmodem or even tftpdnld here. Kindly advise!
thanks for reply
but problem is different.actually i am not getting xmodem command on 7206 vxr router.when i use xmodem command by using console,from rommode router says no such command.is their any way to upload the ios on 7206 vxr router from rom mode.because ios on pcmca card may be corrupted.
pls help urgentaly.
Hello
Not used it on a 7200 rtr but try the following:
Kind Regards
Paul
