2960x stacking question
davis.erm
I have stacked together 3 2960x switches as shown in here:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960xr/hardware/installation/guide/b_c2960xr_hig/b_c2960xr_hig_chapter_010.html#ID173
From top: 1st is the master, 2nd un 3rd are members. The cabling is rechecked to be correct and switch priorities are set up in IOS.
Recently I installed Cisco Network Assistant and in there I see different switch order in stack.
In topology view instead of sw1, sw2, sw3 the order in stack shows as sw1, sw3, sw2.
Why is that so ?
Thanks!
petenixon
Level 3
Level 3
Can you post the output of a show switch please?
