32 bit Autonomous Systems
Does anyone know how i can find out which IOS version support 32 bit ASN's.
I have tried the software tool on the site but no joy yet.
PD
mohammedmahmoud
Level 11
Level 11
While searching on the same a while ago, i found the following:
GSR with a PRP-1 or PRP-2, and at least Engine 3 line cards, you can run IOS-XR 3.4 which fully supports 32-bit ASNs.
While it is not supported yet for IOS.
HTH,
Mohammed Mahmoud.
Thanks!
You are very welcomed, you can check the following article its a very nice one regarding this topic:
Exploring Autonomous System Numbers
http://www.cisco.com/web/about/ac123/ac147/archived_issues/ipj_9-1/autonomous_system_numbers.html
and thank you for using the rating system.
HTH,
Mohammed Mahmoud.
