3560 and mls qos drops
cmwester81
We have a problem with our WS-C3560V2-24TS running IOS c3560-ipservicesk9-mz.122-53.SE2.bin.
The equipment keep dropping packets for no apperent reason.
This is what we are seeing:
LAN-port
Router0#sh interfaces fastEthernet 0/2 | include drops:
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 20595
WAN-port
Router#sh interfaces GigabitEthernet0/1 | include drops
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2460
Port configuration:
Router#sh running-config interface gigabitEthernet 0/1
Building configuration...
Current configuration : 339 bytes
interface GigabitEthernet0/1
description unused
switchport trunk allowed vlan 3596,3597
switchport mode trunk
bandwidth 1000000
speed nonegotiate
srr-queue bandwidth share 1 19 79 1
srr-queue bandwidth shape 4 0 0 0
srr-queue bandwidth limit 10
priority-queue out
mls qos trust dscp
end
Router#sh running-config interface fastEthernet 0/2
Current configuration : 168 bytes
interface FastEthernet0/2
switchport access vlan 901
switchport mode access
bandwidth 100000
speed 100
duplex full
priority-queue out
mls qos vlan-based
end
QoS/MLS
We have tried to increase the queue-set values to the following:
Router#show mls qos queue-set 1
Queueset: 1
Queue     :       1       2       3       4
buffers   :      20      40      20      20
threshold1:     400    2000    1500    1500
threshold2:     400    2000    1500    1500
reserved  :     100     100     100     100
maximum   :     400    2000    1500    1500
But we dont see any improvment.
The QoS/MLS config is as follows:
mls qos map dscp-cos  8 9 10 12 14 16 17 18 to 3
mls qos map dscp-cos  20 22 32 33 34 36 38 48 to 3
mls qos srr-queue output dscp-map queue 1 threshold 1 9 10 12 14
mls qos srr-queue output dscp-map queue 2 threshold 1 17 18 20 22
mls qos srr-queue output dscp-map queue 3 threshold 1 33 34 36 38
mls qos queue-set output 1 threshold 1 400 400 100 400
mls qos queue-set output 1 threshold 2 2000 2000 100 2000
mls qos queue-set output 1 threshold 3 1500 1500 100 1500
mls qos queue-set output 1 threshold 4 1500 1500 100 1500
mls qos queue-set output 1 buffers 20 40 20 20
mls qos
class-map match-all ef.2001
match access-group 2001
class-map match-all af3.ldp.2006
match access-group 2006
class-map match-all df.ldp.2011
match access-group 2011
policy-map qoslan_vlan901_in
class ef.2001
  set dscp ef
class af3.ldp.2006
  set dscp af31
class df.ldp.2011
  set dscp default
Router#sh ip access-lists 2011
Extended IP access list 2011
    10 permit ip any any (518944 matches)
Router#sh ip access-lists 2001
Extended IP access list 2001
    10 permit ip any any precedence critical
    20 deny ip any any (518944 matches)
Router#sh ip access-lists 2006
Extended IP access list 2006
    10 permit ip any any precedence flash
Interface counters
ti280486534j580#sh interfaces counters errors | include Port|Fa0/2 |Gi0/1
Port        Align-Err     FCS-Err    Xmit-Err     Rcv-Err  UnderSize  OutDiscards
Fa0/2               0           0           0           0          0        20952
Gi0/1               0           0           0           0          0         2460
We are shaping the gig uplink to 100Mbps, the equipment is dropping pakets randomly and not because the shaper kicks in and starts to drop pakets.
We really need some help on how to fix this as we are seeing the same thing on many of our routers.
If we turn off the mls qos the problem goes away so it is definitly connected to the mls qos in some way.
Best regards
Magnus
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
It's possible the reason you see the drops when QoS is enabled, but not when disabled, 3560s (and 3750s) allocate one queue's buffer resources to four queues when QoS is enabled.  If that's the issue, you might be able to mitigate by buffer tuning.
If you haven't seen it, you might want to look over: https://supportforums.cisco.com/docs/DOC-8093
