3560 IOS Features
Dear all ,,
i have this IOS for 3560 switch (
c3560-ipservicesk9-mz.150-1.SE1.bin )
and i want to know all the features it includes ,, i used the cisco feature navigator tool through this link  ( http://tools.cisco.com/ITDIT/CFN/Dispatch?act=rlsSelect&task=search&searchby=image )  but this tool canont find the features ,  it shows this message
The Image Name you entered does not match any supported Cisco software releases in this tool.
any one have an idea about how to know know the features of this IOS .?
Best Regards
3 Accepted Solutions
vmiller
Level 7
Level 7
make sure if you do a search with FN you:
take the .bin off the end
select IOS
select cat3550 in the platform (its a long list)
vmiller
Level 7
Level 7
Objective:             Define a specific software image in order to view its supported features.
Select from the pull down menus to find releases which support particular platform             and feature set combinations.View your results in the table below and repeat as             necessary to define a specific software image.
Your Selections:
All Software
Orderable Software Only
Software IOS
Major Release 15.0SE
Release
Platform
Feature Set/License(s)
New Search
Search Results
Image Info
Image Name   c3560-ipservicesk9-mz.150-1.SE.bin
DRAM / Min Flash   128 / 32
Enterprise Product Number
Compare Images                             View MIBs                             Release Notes                             Image Unavailable
Note:  A feature may appear in more than one technology.
Features
AAA Server Group
Access Switch Device Manager (SDM) Template
ACL - Improved Merging Algorithm
ACL - TCP Flags Filtering
ACL Sequence Numbering
Additional Vendor-Proprietary RADIUS Attributes
Address Resolution Protocol (ARP)
ANSI TIA-1057 LLDP -  MED Support
ANSI TIA-1057 LLDP - MED Location Extension
ARP Optimization
Auto QoS enhancements for video endpoints
Auto Smart Ports
Auto Smart Ports and Device classifier
AutoQoS - VoIP
BGP
BGP 4
BGP 4 Multipath Support
BGP 4 Prefix Filter and In-bound Route Maps
BGP 4 Soft Config
BGP Convergence Optimization
BGP Hide Local-Autonomous System
BGP Named Community Lists
BGP Prefix-Based Outbound Route Filtering
BGP Restart Neighbor Session After max-prefix Limit Reached
BGP Route-Map Continue
BGP Route-Map Continue Support for Outbound Policy
BGP Soft Reset
Broadcast/Multicast Suppression
Call Home
CDP (Cisco Discovery Protocol) Version 2
CEF/dCEF - Cisco Express Forwarding
CEFv6 Switching for 6to4 Tunnels
CEFv6/dCEFv6 - Cisco Express Forwarding
CGMP - Cisco Group Management Protocol
Cisco IP Phone Support
CISCO-PORT-QOS-MIB Enhancement
Class Based Ethernet CoS Matching & Marking (802.1p & ISL CoS)
Class-Based Marking
Class-Based Shaping
Clear Counters Per Port
CLI String Search
Client Information Signalling Protocol (CISP)
Commented IP Access List Entries
Common Session-ID logging enhancement
Configurable IGMP Leave Timer
CONFIGURABLE OPTION TO TURN OFF DOT1X, MAB & AUTHMGR INFORMATIONAL MESSAGES
Configuration Replace and Configuration Rollback
Contextual Configuration Diff Utility
Cos/DSCP exchange using LLDP
DHCP -  Server Port Based Address Allocation
DHCP - DHCPv6  Relay Agent notification for Prefix Delegation
DHCP - DHCPv6 Individual Address Assignment
DHCP - DHCPv6 Server SNTP, NIS, NIS+, Refresh Timer options
DHCP Auto Image upgrade
DHCP Auto Install with Saved Configuration
DHCP Client
DHCP Client Option 12
DHCP Server
DHCP Server Options - Import and Autoconfiguration
DHCP Snooping
DHCP Snooping Counters
DHCP Snooping Option 82 enhancement for circuit-id string
DHCPv6 - Relay - Reload persistent Interface ID option
DHCPv6 Client Information Refresh Option
DHCPv6 Ethernet Remote ID option
DHCPv6 Repackaging
Diagnotics Options on bootup
Duplication Location Reporting Issue
Dynamic Trunking Protocol (DTP)
Embedded Event Manager (EEM) 2.3
Embedded Event Manager (EEM) 3.2
EnergyWise
EnergyWise 2.5
Enhanced IGRP (EIGRP)
Enhanced Password Security
Enhanced Tracking Support / Enhanced Object Tracking / EOT
ErrDisable Reactivation Per Port
ErrDisable timeout
EtherChannel
EtherChannel - Flexible PAgP
Etherchannel Guard
Fallback Bridging
Fast EtherChannel (FEC)
Fast-Switched Policy Routing
FHRP - HSRP - Hot Standby Router Protocol V2
Flex Link Bi-directional Fast Convergence
Flex Link VLAN Load-Balancing
Flex Links
Flex Links Interface Preemption
FTP Support for Downloading Software Images
GOLD - Generic Online Diagnostics
HSRP for IPv6
HTTP Security
HTTPS - HTTP with SSL 3.0
IEEE 802.1ab LLDP (Link Layer Discovery Protocol)
IEEE 802.1p Support
IEEE 802.1Q Tunneling
IEEE 802.1Q VLAN Trunking
IEEE 802.1s - Multiple Spanning Tree (MST) Standard Compliance
IEEE 802.1s VLAN Multiple Spanning Trees
IEEE 802.1t
IEEE 802.1W Spanning Tree Rapid Reconfiguration
IEEE 802.1x - Auth Fail Open
IEEE 802.1X - Flexible Authentication
IEEE 802.1x - VLAN Assignment
IEEE 802.1x Authenticator
IEEE 802.1x Fallback support
IEEE 802.1x Multi-Domain Auth with Voice VLAN Assignment
IEEE 802.1X Multi-Domain Authentication
IEEE 802.1x RADIUS Accounting
IEEE 802.1x Readiness Check
IEEE 802.1x Supplicant Support for EAP-FAST
IEEE 802.1x Supplicant Support for MD5
IEEE 802.1X Voice Aware Security Violations
IEEE 802.1x with Port Security
IEEE 802.3ad Link Aggregation (LACP)
IEEE 802.3af PoE (Power over Ethernet)
IEEE 802.3x Flow Control
IGMP Fast Leave
IGMP Proxy
IGMP Querier
IGMP Snooping
IGMP State Limit
IGMP Version 1
IGMP Version 2
IGMP Version 3
Image Verification
Integrated ISIS Point to Point Adjacency over Broadcast Media
Interface Index Persistence
Interface Range Specification
IP Enhanced IGRP Route Authentication
IP Named Access Control List
IP Phone Detection Enhancements
IP Phone Enhancement - PHY Loop Detection
IP Routing
IP Source Guard
IP Summary Address for RIPv2
IPv6 (Internet Protocol Version 6)
IPv6 - HTTP(S)
IPv6 - QoS Trust
IPv6 Access Services: DHCPv6 Relay Agent
IPv6 Data Link: VLANs using Cisco Inter-Switch Link (ISL)
IPv6 Data Link: VLANs using IEEE 802.1Q Encapsulation
IPv6 Default Router Preference
IPv6 Dual Stack
IPv6 MTU Path Discovery
IPv6 Neighbor Discovery Throttling
IPv6 Routing - EIGRP Support
IPv6 Routing: OSPF for IPv6 (OSPFv3)
IPv6 Routing: RIP for IPv6 (RIPng)
IPv6 Routing: Route Redistribution
IPv6 Routing: Static Routing
IPv6 Routing: Unicast Routing
IPv6 Security: Secure Shell SSH support over IPv6
IPv6 Services: AAAA DNS Lookups over an IPv4 Transport
IPv6 Services: Cisco Discovery Protocol (CDP) - IPv6 Address Family Support for Neighbor Information
IPv6 Services: DNS Lookups over an IPv6 Transport
IPv6 Services: Extended Access Control Lists
IPv6 Stateless Auto-configuration
IPv6 Switching: CEF/dCEF Support
IPv6 Switching: CEFv6 Switched Configured IPv6 over IPv4 Tunnels
IPv6 Switching: CEFv6 Switched ISATAP Tunnels
IPv6: ICMPv6
IPv6: ICMPv6 Redirect
IPv6: Neighbor Discovery Duplicate Address Detection
IS-IS HMAC-MD5 Authentication
IS-IS Incremental Shortest Path First (i-SPF) Support
IS-IS Limit on Number of Redistributed Routes
IS-IS Mechanism to Exclude Connected IP Prefix from LSP Advertisements
IS-IS Multiarea Support
IS-IS Support for IP Route Tags
ISIS
ISL VLAN
Jumbo Frames
L2PT - Layer 2 Protocol Tunneling
LLDP Power Assignment
Local Proxy ARP
MAC Authentication Bypass
MAC Move
MAC Replace
Message Banners for AAA Authentication
MLD Snooping
Multi-auth Vlan Assignment
Multi-host Mode with EPM
Multi-VRF Support (VRF lite)
Multicast BGP (MBGP)
Multicast Etherchannel Load Balancing
Multicast Fast Convergence with Flexlink Failover
Multicast Source Discovery Protocol (MSDP)
Multicast Subsecond Convergence
NAC - L2 IEEE 802.1x
NAC - L2 IP
NAC - L2 IP with Auth Fail Open
Network Time Protocol (NTP)
NSF - OSPF
NSF Awareness - BGP
NSF Awareness - EIGRP
NSF Awareness - OSPF
OSPF
OSPF for Routed Access
OSPF Forwarding Address Suppression in Translated Type-5 LSAs
OSPF Inbound Filtering using Route Maps with a Distribute List
OSPF Not-So-Stubby Areas (NSSA)
OSPF Support for Multi-VRF on CE Routers
OSPFv3 Graceful Restart
Packet-Based Storm Control
Parse Bookmarks
Parser Cache
PIM Dense Mode State Refresh
PIM MIB Extension for IP Multicast
PIM Multicast Scalability
PIM Version 1
PIM Version 2
Policy-Based Routing (PBR)
Port Security
Port Security on Private VLAN Ports
Priority Queueing (PQ)
Private VLANs
Propagation of Location Info over CDP
QoS Packet Marking
RADIUS
RADIUS Attribute 44 (Accounting Session ID) in Access Requests
RADIUS Change of Authorization (CoA)
RADIUS for Multiple User Datagram Protocol Ports
RADIUS Server Load Balancing
RADIUS Tunnel Attribute Extensions
Random Early Detection (RED)
Rapid-Per-VLAN-Spanning Tree (Rapid-PVST)
Reduced MAC Address Usage
Remote SPAN (RSPAN)
Resilient Ethernet Protoco (REP) LSL Ageout timer improvements
RIP
RMON events and alarms
RSVP - Resource Reservation Protocol
RTP Header Compression
Secure Copy (SCP)
Secure Shell SSH Version 1 Integrated Client
Secure Shell SSH Version 1 Server Support
Smart Logging and Telemetry (SLT)
Smart Port
SNMP (Simple Network Management Protocol)
SNMP Inform Request
SNMP Manager
SNMP over IPv6
SNMPv2C
SNMPv3 (SNMP Version 3)
Software Based Protocol Rate Limiting (a.k.a PSP Protocol Strom Protection)
Spanning Tree Protocol (STP)
Spanning Tree Protocol (STP) - Backbone Fast Convergence
Spanning Tree Protocol (STP) - Loop Guard
Spanning Tree Protocol (STP) - Portfast
Spanning Tree Protocol (STP) - PortFast BPDU Filtering
Spanning Tree Protocol (STP) - Portfast BPDU Guard
Spanning Tree Protocol (STP) - Portfast Support for Trunks
Spanning Tree Protocol (STP) - Root Guard
Spanning Tree Protocol (STP) - Uplink Fast Convergence
Spanning Tree Protocol (STP) - Uplink Load Balancing
Spanning Tree Protocol (STP) Extension
SRR (Shaped Round Robin)
Standalone MAB support
Standard IP Access List Logging
Standby Supervisor Port Usage
STP Syslog Messages
Stub IP Multicast Routing
Subnetwork Bandwidth Manager (SBM)
Support for 4096 VLAN IDs
Switch Port Analyzer (SPAN)
Syslog over IPV6
Tacacs Single Connection
TACACS+
Time-Based Access Lists
Time-Based Access Lists Using Time Ranges(ACL)
Transparent Bridging
Trunk Failover
Trusted boundary (extended trust for CDP devices)
TrustSec SXP SNMP and Syslogs
UDI - Unique Device Identifier
Unicast Mac Filtering
UniDirectional Link Detection (UDLD)
VACL Logging of access denied
Vendor-Specific RADIUS Attributes
Virtual Router Redundancy Protocol (VRRP)
VLAN Access Control List (VACL)
VLAN Aware Port Security
VLAN-ID Based MAC Authentication
VTP version 3
WCCP Redirection on Inbound Interfaces
WCCP Version 1
WCCP Version 2
Web Authentication Proxy
Webauth Enhancements
Weighted Tail Drop (WTD)
Some features are dependent on product model, interface modules  (i.e. Line Cards & Port Adapters), and/or require a software feature  license.     Click here for more information.
I just kept lopping off characters from the filename he sent until I got a hit on feature navigatior. My best guess is that its close enough for his needs.
Glad to see you are back.
12 Replies 12
Leo Laohoo
Cisco IOS Software Packaging and Licensing
Please don't forget to rate our useful posts. Thanks.
vmiller
Level 7
Level 7
select IOS
Richard Burts
Mohammed
I looked on the software download page and I can not find an image with that name. The images for 3560 that I can find that have ipservices in the name do not have versions in 15.0SE1. And the images that I can find in  15.0SE1 have universal as the feature identifier.
My search was a bit approximate since you did not give us any details about the swtich that you intend to run this on. Perhaps if you provide more details we might be able to find better answers about what is available.
Rick
Rick
vmiller
Level 7
Level 7
Your Selections:
All Software
Software IOS
Release
Platform
New Search
Search Results
Image Info
Features
AAA Server Group
ARP Optimization
Auto Smart Ports
AutoQoS - VoIP
BGP
BGP 4
BGP 4 Soft Config
BGP Soft Reset
Call Home
Class-Based Marking
Class-Based Shaping
CLI String Search
DHCP Client
DHCP Server
DHCP Snooping
DHCPv6 Repackaging
EnergyWise
EnergyWise 2.5
ErrDisable timeout
EtherChannel
Etherchannel Guard
Fallback Bridging
Flex Links
HSRP for IPv6
HTTP Security
IEEE 802.1p Support
IEEE 802.1t
IGMP Fast Leave
IGMP Proxy
IGMP Querier
IGMP Snooping
IGMP State Limit
IGMP Version 1
IGMP Version 2
IGMP Version 3
Image Verification
IP Routing
IP Source Guard
IPv6 - HTTP(S)
IPv6 - QoS Trust
IPv6 Dual Stack
IPv6: ICMPv6
ISIS
ISL VLAN
Jumbo Frames
Local Proxy ARP
MAC Move
MAC Replace
MLD Snooping
NAC - L2 IP
NSF - OSPF
NSF Awareness - BGP
OSPF
Parse Bookmarks
Parser Cache
PIM Version 1
PIM Version 2
Port Security
Private VLANs
QoS Packet Marking
RADIUS
Remote SPAN (RSPAN)
RIP
Secure Copy (SCP)
Smart Port
SNMP Inform Request
SNMP Manager
SNMP over IPv6
SNMPv2C
STP Syslog Messages
Syslog over IPV6
TACACS+
Trunk Failover
VTP version 3
WCCP Version 1
WCCP Version 2
Leo Laohoo
One gotcha ...
If your 3560 has 16mb of flash, you CANNOT use this IOS.
I am glad that the original poster has marked the question as answered. But I am puzzled how he identified that IOS version as c3560-ipservicesk9-mz.150-1.SE1.bin and the answer marked as correct was about c3560-ipservicesk9-mz.150-1.SE.bin
Rick
Rick
Hi Rick,
Haven't seen you posting for awhile.  Hope you are well.
Leo
Glad to be back. Yes things are pretty well.
Rick
Rick
yes vmiller , thatss true man , and after i will go back to my company i ll pick  the part No. of the switch and put it here
thanks all for your interests
SE1 is fairly new (release date 02 December 2011).
Maybe documentation hasn't caught up yet.
yes vmiller ,, thats true , and  after i ll go back to my company i ll  pick up the part No. of the switch and put it here ,,
