IOS Image disappeared!
tahequivoice
Level 2
Level 2
I did a copy tftp of a new IOS image, did a dir, it showed up on the flash, saw no errors, and a little while later after getting a window to reload, scheduled the reload on the router and just as a forethought, double checked the image, and it was gone, the flash was empty.
What would cause this to happen?  I uploaded the image again using ftp after finding the reason ftp didnt work the first time, ftp was blocked on the firewall.
Directory of flash:/
No files in directory
64016384 bytes total (64016384 bytes free)
results of my last upload
[OK - 34103624/4096 bytes]
34103624 bytes copied in 187.852 secs (181545 bytes/sec)
    1  -rw-    34103624  Dec 15 2011 10:31:08 -06:00  c2800nm-spservicesk9-mz.124-25f.bin
I had to delete the existing image to make room for the new one, I couldnt load both, so this is a scary situation as it is a remote location.
Leo Laohoo
Your flash could be faulty.
