35b& G.FAST is only supported on C1112-8PLTEEA and C1113-8PLTEEA.
i-elbagouri
I am seeking your support regarding the following issue. Both routers, C1112-8PLTEEA and C1113-8PLTEEA, are now end-of-sale, and I need a replacement router that supports the VDSL 35b profile. However, I could not find any replacement product on the Cisco website.
Could you please advise on the best alternative model available?
E 1846667
The Cisco routers C1112-8PLTEEA and C1113-8PLTEEA are end-of-sale, and currently, there is no direct replacement product available for these models. However, for routers supporting the VDSL 35b profile, you might consider the Cisco ISR 1100 Series, specifically models like C1116-4P and C1117-4P, which support VDSL2 profiles including 35b. These models offer flexible WAN and LAN connectivity options and are part of the ISR 1000 Series portfolio, which includes DSL variants suitable for various deployment needs. For more detailed specifications, you can refer to the Cisco 1000 Series Integrated Services Routers Data Sheet
