3620 doesnt boot, could any advice ??
aghiadb
Dear sir:
after we transfer the ios to flash using xmodem the following message appear after download complete :
open: file "n" not found
open(): Open Error = -1
Copyright (c) 1999 by
loadprog: error - on file open
after reset te router the following message appear :
Error : uncompressed image checksum is incorrect 0x19CE6603
Expected a checksum of 0x4DF0F984
*** System received a Software forced crash ***
signal= 0x17, code= 0x9, context= 0x0
PC = 0x800080d4, Cause = 0x20, Status Reg = 0x3041f003
although we changed the flash with new one,and more than two different IOS.
please advice
many thanks
Aghiad Boukai
b-ulrich
Level 3
Level 3
Hi, you probably want to get into rommon and try to manually boot to one of your IOS images that was working before. If they are not listed, you probably will have to re-tftp it or xmodem it.
