3650x switch crypto sec tunnels
Marc Day
morning/afternoon
Does anyone know if you can create a crypto sec tunnel on a 3650x switch?
Cheers
Marc
hobbe
Level 7
Level 7
what do you want to connect it to ?
This is important to know first.
it will be a cypto sec tunnel the other end will be a 720 processor....config something like
crypto ipsec transform-set ??? ah-md5-hmac esp-3des
crypto map ??? 10 ipsec-isakmp
set peer ???.???.???.???
set transform-set ???
match address ???
meant to say this will be an ethernet service
I am not shure that is possible. or rather I am pretty shure that it is not possible.
you can afaik only do this to the nexus 7K.
to other 3560x/3750x is not possible today, but will be afaik during spring/summer.
and some new switches 3560c/2960c will also work as soon as they start shipping in a month or two.
What you are looking for in the 3560x is 802.1ae or MACsec.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_55_se/configuration/guide/sw8021x.html#wp1316656
so for now sorry but I do not know of anyway you can do this.
Good luck
