3745 PSU status logging
k.protopapas
I need to monitor and see in the logs the error and status messages of the PSUs in a 3745 with IOS 12.4(10) Advianced IP Services images.I get those notifications on the console but not on the logs.Thank you in advance for your help.
satish_zanjurne
Level 4
Level 4
1. Use following commands , to make router do the logging in buffer
"logging buffered 16384"
"logging on"
2.use "show log" to see the logs
3.In addition use "logging monitor" to see the logs on terminal lines like vty
HTH...rate if helpful..
I have already enabled the system logging,but it doesnt log the PSU status.
