3745 router does not accept any key input
joel
I have a 3745 router that boots, displays all the boot information while booting, but after it boots and says "Press Return to get started" it dos not accept any keyboard input.
I wanted to try to boot the router in ROMMON mode to see if the baud rate is mismatched, but I am not able to use "CTRL +Break" to go into rommon.
I have removed all cards from it and it only has CISCO3745-IO-2FE blade.
Help!!!
Giuseppe Larosa
Hello joel,
use
9600 baud rate
8 bit
1 bit stop
no parity
flow control xon/xoff
verify the cable on another cisco device
have the console before powering up the router
see also
http://www.cisco.com/en/US/docs/routers/access/3700/3745/hardware/quick/guide/3745qsg.html
Hope to help
Giuseppe
joel
The attachment has the log from the boot process.
Giuseppe Larosa
Hello joel,
use
9600 baud rate
8 bit
1 bit stop
no parity
see also
Hope to help
Giuseppe
thanks for the reply...
tried the cable on another router and got the same result...
changed the console cable and it works fine now. Thanks...
I sure learnt it the hard way through...
joel
