3750 and BGP
rajivrajan1
Level 3
Level 3
I need a clarification reg 3750-48 port switch.
With default ram and settings, can i use this switch in a production environment to run bgp?
any considerations?
Possiblity
1.Full internet routing table may flow in near future.
2.PVLAN and multiple trunks are there in the switch already.
3. Four-six private subnets these switches has to carrry using static routes
pls guide
rajivrajan1
Level 3
Level 3
is there anyone running bgp in 3750?please guide
thomas.anthony
3750 has the capability of running BGP like Advanced IP unicast routing protocols (Open Shortest Path First [OSPF], Interior Gateway Routing Protocol [IGRP], Enhanced IGRP [EIGRP], and Border Gateway Protocol Version 4 [BGPv4]) but The IP Services image is required. But I would never advice 3750 if you want to inject internet routes to it. Simply it can?t handle.
There are some unsupported BGP commands on 3750 have a look before you get on.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.1_19_ea1/configuration/guide/swuncli.html#wp1025053
thanx buddy rated full.
