3750 disabling AAA
aksher
How to disable AAA on 3750 switch which has got screwed up. I believe RMON mode will not work?
Anand Narayana
Level 6
Level 6
Hi Askher,
juz follow the steps.
3750(config)#no aaa new-model.
mohammedmahmoud
Level 11
Level 11
Just bypass loading the configuration and then use "no aaa new-model".
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
bjornarsb
Level 4
Level 4
If this is a router in service, i believe that you do not want down-time. Use an acl in one of your other routers or firewalls on the way to the AAA server. Then when the 3750 has no access to the aaa server it will use local auth. if you have enabeled :
aaa authentication login default group tacacs+ local
HTH,
Bjornarsb
guruprasadr
Level 7
Level 7
HI Aksher,
In the Global configuration mode:
#no aaa new-model
For additional level:
#no aaa authentication login {default | list-name} method1 [method2...] global configuration command.
Pls Rate If Helps ! !
Best Regards,
Guru Prasad R
