3750 routing question. Please help
IvanZabaluyev
Dear community,
I am a newbie at Cisco, working on getting my CCNA, and I am trying to make my LAB 3750 switch to work for me at my home network configuration.
I have 2 Vlans.
I configured Vlan interfaces,
Port configuration:
G1/0/1 - connected to the cable modem. IP address DHCP.
G1/0/2 - connected to WiFi Router to make wifi separate
Ip address 10.0.30.1/24
G1/0/3-12 VLAN 10, DANTE network
Interface VLAN 10:
10.0.10.1 /24
G1/0/13-24 - VLAN 20, Home Ethernet.
Interface VLAN 20:
10.0.20.1 /24
IP Routing enabled.
Ping is working nice between devices in VLANs.
And ping working nice from the devices in VLANs and Gi1/0/1 DHCP gained address.
Ping working fine from the switch to the external world.
!!! But when I am trying to ping the world address from the Vlan interface on the switch, - success rate is 0
Here is conf:
Current configuration : 4829 bytes
version 12.2
no service pad
hostname Zaba_SW1
boot-start-marker
boot-end-marker
! EN secret and password data deleted !
no aaa new-model
switch 1 provision ws-c3750g-24ts-1u
system mtu routing 1500
vtp mode off
ip routing
ip domain-name ZABANET
ip dhcp excluded-address 10.0.10.1
ip dhcp excluded-address 10.0.20.1
ip dhcp excluded-address 10.0.30.1
ip dhcp pool DANTE
   network 10.0.10.0 255.255.255.0
   dns-server 68.111.106.68 208.67.222.222 208.67.220.220 8.8.8.8 4.4.4.4
   default-router 10.0.10.1
ip dhcp pool Ethernet_Home
   network 10.0.20.0 255.255.255.0
   default-router 10.0.20.1
ip dhcp pool Google_WiFi
   network 10.0.30.0 255.255.255.0
   default-router 10.0.30.1
! SSH configuration part deleted!
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 10
 name DANTE
vlan 20
 name Ethernet_Home
ip ssh version 1
interface GigabitEthernet1/0/1
 no switchport
 ip address dhcp
interface GigabitEthernet1/0/2
 description GoogleWiFi
 no switchport
 ip address 10.0.30.1 255.255.255.0
interface GigabitEthernet1/0/3
 switchport access vlan 10
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
 switchport access vlan 20
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
 no ip address
interface Vlan10
 ip address 10.0.10.1 255.255.255.0
interface Vlan20
 ip address 10.0.20.1 255.255.255.0
ip classless
ip http server
ip http secure-server
vstack
line con 0
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
end
__________________________________________
Zaba_SW1# sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 68.5.24.1 to network 0.0.0.0
     68.0.0.0/21 is subnetted, 1 subnets
C       68.5.24.0 is directly connected, GigabitEthernet1/0/1
     10.0.0.0/24 is subnetted, 2 subnets
C       10.0.30.0 is directly connected, GigabitEthernet1/0/2
C       10.0.20.0 is directly connected, Vlan20
S*   0.0.0.0/0 [254/0] via 68.5.24.1
Please help.
Thank you for your attention.
Ivan
You are quite correct that a real router with NAT will solve this problem, will provide Internet connectivity, and would have other features that you might find useful.
Rick
10 Replies 10
luckymike33
Hi Ivan,
I did not see any mention anywhere of a route back to those subnets you created, being configured on your cable modem?
Mike
Thank you Mike for your reply.
I have a Motorola cable modem with no configuration through the web interface. It is accessible via the web interface by address 192.168.100.1
There is no routing configuration inside. This part is a total dark matter for me. The modem accessible with 192.168.100.1 address, and it is connected to port g1/0/1, that received address 68.5.24.49/21 by DHCP from the modem. and when I am logging to the web interface of the modem by address 192.168.100.1, the system reports that my IP address is: 10.71.31.19.
If you mean routing configuration inside the switch, please be more specific. A far as I understand I have SVIs for VLANs, that show IP route reported as directly connected, I have directly connected network 68.0.0.0/21 that is connected to the internet,
As I said before I can ping internet from the switch, but when I am trying to ping from the 10.0.20.1 to the internet I have 0 success.
Thank you again for your reply. But I really don't get it. If you have some time, please point me to my mistake.
Thank you
The main issue here is that your switch is using "private" IP addressing. To access resources in the public Internet you need address translation. Unfortunately your switch does not support configuration of address translation. If there is a way to get address translation on the cable modem your network would work. But without address translation it will not.
Rick
Thank you, Richard, so much for the detailed explanation. I gonna look for another solution with NAT.
Best Regards.
Ivan.
what type/model is your Motorola cable modem (e.g. MG 7550) ?
Hello George,
It is MB7621
Thank you.
I checked the user guide for the MB7621, not much you can configure unfortunately. They are talking about reserved guest networks for other types, you could try if these guest networks also work on the MB7621, that is, change your DHCP pools and make them use these guest networks. e.g.:
network 192.168.1.0 255.255.255.0
network 192.168.2.0 255.255.255.0
--> The MG7550 and MG7540 reserve subnets 192.168.1.x & 192.168.2.x, and 192.168.21.x & 192.168.22.x for Guest networks. These reservations cannot be changed.
The MG7310 and MG7315 reserve subnets 192.168.1.x through 192.168.7.x for Guest networks. These reservations cannot be changed.
Thanks, George
I will try to make it tomorrow, but I feel, that I probably need to use a real router, with NAT, and additional features.
Thank you.
Best Regards,
Ivan
Ivan
Rick
Ivan
This has been an interesting discussion and it involves an issue that comes up frequently when discussing access to Internet from private networks. I am glad that our explanations and suggestions have been helpful. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
