3750 - Total output drops - Issue
parm UK
Hi Guys,
Im hoping for some assistance.
We own a small building rented out as managed office space.  As part of this we have a 1Gb internet feed which we then distribute throughout the building.  With each customer / office having their own managed firewall.   Connectivity is sold as either 10Mb or 100Mb.
So we have a 1Gb internet feed out from our ISP router (rj45) into a 3750.  To which the managed firewall is attached, port speed is set manually to 10 or 100 depending on require connectivity as above.
The 3750 is completly flat, no vlans, QoS disabed (default) - no duplex issues, etc
on certain interfaces i'm seeing output drops as per;
GigabitEthernet1/0/8 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is acf2.c501.7688 (bia acf2.c501.7688)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 3/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 1y18w, output 00:00:00, output hang never
  Last clearing of "show interface" counters 20:57:21
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 20156
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 327000 bits/sec, 184 packets/sec
5 minute output rate 1409000 bits/sec, 204 packets/sec
     6280347 packets input, 1668073759 bytes, 0 no buffer
     Received 2520 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     9141511 packets output, 9402986888 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
QoS is disabled as per
NET#sh mls qos
QoS is disabled
QoS ip packet dscp rewrite is enabled
Hence the drops are not due to this.   I know 3750 has small buffers however we thought it could cope with this.  ?
is the 3750 not up to the job?
I know this may be caused my microbursts - but do these not effect LAN switchs?  I thought as this switch site betwwen ISP router and customer firewalls this should nto be the case.
Any help appreciated.
Thanks in Advance
ParmbUK
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It's likely, as you've already supposed, the 3750's small buffers are getting exhausted during some burst.  (Microbursts also apply to LANs.)
Disabling QoS, on a 3750, avoids queuing resource issues caused by default QoS settings, but I've found, you can sometimes dramatically decrease drops, by enabling queuing and tuning the buffer settings.  (I've found tuning the 3750 to work more from its common pool, rather than reserved interface pools, does the trick if not all ports are busy at the same time.)
The 3750 provides 2 MB of buffer RAM per 24 edge ports and for its uplink ports, so how you place busy ports can be important too.
