3800 dBm
brian.kennedy
Is there a command to find your optical tx/rx power (dBm) on a 3845?  On a 3750 you can do a show int transceiver;  looking for a comparable command for ISRs.
Brian
paolo bevilacqua
That features (called Digital Optical Monitoring), is dependant from the specific type of module used, not all have it, these that don't cannot report the power values.
Leo Laohoo
Not sure if you can do this on a router but the SFP should have the "D" in the end of the part number like GLC-SX-MMD.   This means that the SFP can support DOM.
End-of-Sale and End-of-Life Announcement for the Select Cisco Gigabit Ethernet SFP Modules
