887VA ADSL - Service Policy brings down link
Nishant Jethwa
Have installed an 887VA on the end of a ADSL connection. The provider has specified EF 150 on the link. The router is configured using a Virtual Template.
If the Virtual Template has a service policy applied, we don't have connectivity to their main site - although the CD and PPP lights are lit. As soon as the service policy is removed, we have connectivity.
We've had three sites with the same problem. Two of the sites don't have QoS specified on the link but had the same problem if the service policy was applied.
Hardware - CISCO887VA-SEC-K9
Software - 15.1(4)M4
=== config snippets
class-map match-all Voice
match access-group 10
policy-map Dscp
class Voice
  priority 150
class class-default
interface ATM0
bandwidth 1143
bandwidth receive 12334
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
bandwidth 1143
ip unnumbered Loopback0
pvc 0/38
  oam-pvc 0
  encapsulation aal5mux ppp Virtual-Template1
interface Virtual-Template1
bandwidth 1143
ppp chap hostname XXXXXXXXXXXX
ppp chap password XXXXXXXXXXXX
ppp ipcp route default
paolo bevilacqua
Try a Dialer interface instead of virtual template.
On setups historically we have used dialers, however the change has been dictated by our provider. They use Virtual Template so we have had to adopt the configuration on our end.
Whatever they use make no difference to you and to what goes on the wire.
Beside that, you can try solutions, go to who dictated you the configuration so can dictate a solution, or stay with the problem - up to you really.
