3825 router, T3 Network Module capability
wilson_1234_2
Level 3
Level 3
I have a DS3 connection to the DR site.
HQ has a 7206 router and DR has a 3725 router with T3 Network Modules
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a008010fba2.html
We have experienced issues of link flapping during heavy traffic throughput.
We had someone mention the 3725 router cannot handle a full T3 at line speed.
I am wondering about this line in the spec:
Full-rate T3/E3 with no services
What does this mean?
The link is Frame Relay with the following config on the interface:
interface Serial1/0
description MCI DS3
no ip address
encapsulation frame-relay IETF
ip route-cache flow
load-interval 30
dsu bandwidth 44210
interface Serial1/0.41 multipoint
description bridged VLAN
frame-relay map bridge 40 broadcast
frame-relay map bridge 41 broadcast
frame-relay interface-dlci 40
frame-relay interface-dlci 41
bridge-group 3
interface Serial1/0.100 point-to-point
ip address 192.168.2.6 255.255.255.252
frame-relay interface-dlci 100
interface Serial1/0.101 multipoint
description Bridged LAN
frame-relay map bridge 101 broadcast
frame-relay interface-dlci 101
bridge-group 1
interface Serial1/0.250 multipoint
description Bridge VLAN
frame-relay map bridge 250 broadcast
frame-relay interface-dlci 250
bridge-group 2
Nagendra Kumar Nainar
Hi Wilson,
Full-rate T3/E3 with no services - means when the router is configured only for packet forwarding (i.e) without any other services like QoS, NAT, ACL enabled. With no services enabled, the CPU will be fully utilised for packet forwarding.
If not, the CPU will be shared by other enabled services and obviously the throughput will be reduced.
If your requirement is T3/E3 line rate with services enabled, 3845 will be the better choice.
Nagendra
