03-10-2015 12:59 PM - edited 03-05-2019 12:59 AM
Dear Members,
I am experiencing high CPU problem on a Cisco 3845 router model, the offending process is name "Collection proce" I found some similar post but turned to switch in order to address this issue and I disabled NetFlow and multicast configuration, but it did not, someone have any suggestions or have had similar problem?
RT01xxx#sh processes cpu sor | exclude 0.00%
CPU utilization for five seconds: 99%/2%; one minute: 99%; five minutes: 99%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
270 123839896 643962 192317 87.88% 86.38% 86.22% 0 Collection proce
127 4801560 14226388 337 8.48% 9.99% 10.07% 0 IP Input
64 66367244 16562996 4006 0.61% 0.61% 0.62% 0 Per-Second Jobs
47 6677576 6317562 1056 0.15% 0.06% 0.06% 0 Net Background
RT01xxx#show processes 270
Process ID 270 [Collection process], TTY 0
Memory usage [in bytes]
Holding: 14884, Maximum: 0, Allocated: 2435077764, Freed: 2435107824
Getbufs: 0, Retbufs: 0, Stack: 9016/12000
CPU usage
PC: 614B22E0, Invoked: 644089, Giveups: 642527, uSec: 192319
5Sec: 85.69%, 1Min: 86.06%, 5Min: 86.16%, Average: 0.00%
Age: 16562402716 msec, Runtime: 123865764 msec
State: Ready to Run, Priority: Low
RT01xxx#show processes cpu history
RT01xxx 04:57:32 PM Tuesday Mar 10 2015 RJO
999999999999999999999999999999999999999999999999999999999999
100 ************************************************************
90 ************************************************************
80 ************************************************************
70 ************************************************************
60 ************************************************************
50 ************************************************************
40 ************************************************************
30 ************************************************************
20 ************************************************************
10 ************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per second (last 60 seconds)
100 ############################################################
90 ############################################################
80 ############################################################
70 ############################################################
60 ############################################################
50 ############################################################
40 ############################################################
30 ############################################################
20 ############################################################
10 ############################################################
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
111 1111 11 1 1 1 1
999000999999990000900902212221222222129919209091222929999012822222122292
999000999999990000900901272217122220709939009098001909999090013111910090
100 ######################* ** * **** * ***** *
90 ######################* ** * **** * ***** *
80 ######################* ** * **** * ***** * *
70 ######################* ** * **** * ***** * *
60 ####################### ** * **** * ***** * *
50 ####################### ** * **** * ***** * *
40 ####################### ** * **** * ***** * *
30 ####################### ** * **** * ***** * *
20 #######################***************** *******************************
10 #######################********#*******#***#*******#**####**************
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
03-11-2015 04:57 AM
This Collection process deals with recursive prefixes updates, with cef.
You should have a look on the routing table, routing protocols, flapping routes, flapping neighbors etc.
what software/IOS of router?
- Ashok
Please rate the post or mark as correct answer as it will help others looking for similar information
03-11-2015 06:54 AM
Hi Ashok,
Thanks for return, this equipment is a CE and wheel getting BGP 3 prefixes and OSPF on the LAN, The wan output link is 2Mbps
the version is "c3845-advsecurityk9-mz.151-4.M7.bin"
Cheers,
Gabriel Farias
