3845 hotswapable ?
littlebrook
Are 3845 chasis hot swapable? can I replace a 48 port card while the unit is running?
Jon Marshall
From the 3800 Q & A
Q. Is online insertion and removal (OIR) supported for modules in the NME slot?
A. Yes. OIR of modules in the NME slot is supported on Cisco 3800 Series routers. OIR is used for replacement of like modules only, and limitations apply per module. Please check the documentation of the individual modules and the OIR procedures before executing this procedure.
Full link -
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/prod_qas0900aecd8016a953.html
Jon
would you have the link to the NME-XD-48ES-2S-P tech notes, they do not seem to be anywhere? I can find generic notes but nothing specific to the 48 port card? thanks
