Hello Srinivas,
the Cisco Feature Navigator can be used for this kind of search
http://www.cisco.com/go/fn
search by feature
then search by image name on the top right of the new window
past the IOS file name
then you can use "view IOS image details" to see all the supported features a new pop up window will be opened with all supported features listed alphabetically.
there are many IPv6 features supported in your image.
What are you looking for exactly ?
Edit:
see attached file an excel with all supported features for your image from Cisco FN
Hope to help
Giuseppe
