Router bandwidth
Dears,
how can I notify my syslog about router bandwidth utilization ?
6 Replies 6
Rahul Kukreja
I beleive RMON is the option available for your requirement.
Check these links if it helps -
http://puck.nether.net/pipermail/cisco-nsp/2008-March/049199.html
http://www.cathayschool.com/using-rmon-to-send-traps-a579.html (Ex 4)
Rahul
Thank you for this valuable information,
however I want the router to send a real time bandwidth utilization (average for example).
If we need real time stats.
My suggestion would be to use Netflow or SNMP.
With the help of netflow we could export the stats to a collector and on collector you could then build the traffic graphs.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
From the Cisco device itself?
If so, you might be able to do this with device scripting.
Can you show me examples?
Disclaimer
Posting
No, but you might ask for that on the EEM scripting forum.
