3845 onboard VPN counters question.
achrich
We use 3845`s to terminate some branch offices with a IPSec/GRE tunnel.
However ive noticed that when doing the stats on the onboard cryto card I get a error I can`t find any info on and wondered if anyone on here had come across it ?
Errors:
0 pkts dropped 0 ppq full
0 tx parts overflow 0 rx parts overflow
0 replenishment failure 0 zero len
0 flow inputs bad 0 cmd invalid
0 IPV4 len 0 algor invalid
0 bad shadow particle 0 algor disabled
0 pre tx fail 0 dma error
0 dbit miss 0 pipeline abort
0 failsafe timeout 0 reserv
0 bad sz count 0 bad shdw
0 bad flow tx 0 spi mismatch
0 bad flow rx 0 auth fail
0 udm fs fail 0 pad fail
0 addr limit fixup fail 0 seq fail
250756555 quad fix sp 0 quad fix mp
0 quad fix cont
vmoopeung
Level 5
Level 5
This looks like an encryption issue. You can find the workaround for the similar kind of issue in the bug bug ID “CSCsd47513".
Thanks for the reply how ever the version of IOS used is not listed for that bug.
3845 is running 12.4-13d.
CPU is running at approx 40% which is what we would expect when encrypting approx 60-70Mb ( wth varying packet sizes )
Hi Ahrich,
I got the same issue with a 12.4(13r)T, but CPU is 20% and I lost 1% traffic.
Did you manage to solve this problem ?
Thanks and best regards
