3845 router Modular QOS on ATM sub-interface
anasubra_2
Hi All,
We were trying to configure Modular QOS on an ATM sub-interface in output direction on a Cisco 3845 router and we get an error message stating CBWFQ not supported on sub-interfaces.The sample config as below
policy-map x
class w
priority percent 20
class y
bandwidth percent 10
We have class-map configured appropriately.
Anantha Subramanian Natarajan
Joseph W. Doherty
QoS will need to "know" the bandwidth of the subinterface to accept the QoS service policy.
(I've often worked with ATM vbr-nrt PVCs that define the subinterface's bandwidth and support a service policy in the subinterface's PVC section.)
Hi Josephdoherty,
Thanks for the response.... Actually we tried to configure the service-policy under the PVC statement on that subif and also the router takes that config but it doesn't show in the config.
Any idea on that
Thank you
Can't say for sure in your case, but I have seen service policies appear to be accepted but not show in the config if they have explicit bandwidths that are more than the interface supports. If you apply the policy from a telnet connection you won't see an error although I've seen the error appear on the console and router log.
In your sample, though, you're using percentages and this should avoid the issue I just described.
Hi Josephdoherty,
