3900 ROUTER flash card not detecing
hi ,
we use 3900 router,today morning when i come to know my default-gateway not able to response,then i connected to console ,i came to know which is in rommon mode ,when i check few command ,noting impact.
in rommon mode i did use some commands plz check
rommon 1 > boot
Compact Flash0: Not present
rommon 2 > boot flash1:
program load complete, entry point: 0x4000000, size: 0x18fa0
boot: cannot determine first executable file name ondevice "flash1:"
rommon 3 > dir flash1:
Directory of flash1:
rommon 4 >reset
System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
Copyright (c) 2010 by cisco Systems, Inc.
Total memory size = 1024 MB - DIMM0 = 512 MB, DIMM1 = 512 MB
CISCO3945-CHASSIS with C3900-SPE150/K9 with 1048576 Kbytes of main memory
Main memory is configured to 72/72(dimm 0/1) bit mode with ECC enabled
Readonly ROMMON initialized
Technical Support: http://www.cisco.com/techsupports
rommon 2 > meminfo
Current Memory configuration is:
DIMM0: Size =  512 MB : Start Phy Addr = 0x0_00000000 (interleaved)
DIMM1: Size =  512 MB : Start Phy Addr = 0x0_00000000 (interleaved)
Main memory size: 1024 MB in 72/72(DIMM0/DIMM1) bit mode.
Available main memory starts at 0x1008000, size 1032160KB
Smart Init is enabled.
NVRAM size: 256 KB
Manufacturer's JEDEC ID code:
DIMM0: 7f94000000000000 (p/n SG572648FG8P0ILSG2)
DIMM1: 7f94000000000000 (p/n SG572648FG8P0ILSG2)
how to resolve this one ?
which cause this problem comes?
plz give me idea
7 Replies 7
Leo Laohoo
Your CF in Slot1 is not formated properly.
If you have a multi-card reader, format this with FAT16, copy the IOS into the CF and try again.
thank u for reply
can u plz tell me which cause that was happend like that because which was running for a long time good
condition but suddenly .
because as per my knowledge ,when that was good condition all configuration which is loaded in ram from flash card ,until then router restated this problem was not happend ?
I am not sure.  By default, your CF should be in Slot 0, but in your case, the CF is in Slot 1.  So some human life form has taken what was in Slot 0 and something, instead, was used in Slot 1.  Could be a third-party (and un-supported) CF in Slot 1.  I don't know as I'm not there.
Yes you are right, what happened when this problem came i thought it may be problem in slot0 so that i manually changed to slot1.
   i am not sure plz tell me this  one point ,
Example:-if i erase flash card or problem in flash card, it never gives me error until then i restart the router. Because all my configuration and ios is loaded in ram?
but my case router is in rommon mode and flash card is empty, then i restarted the router but same result. so i changed flash card in another slot but same output.
And i connected a flash card in my system. card is working and no configuration files (empty) in flash card.
Let me get this straight ... You ERASED all the contents of your CF?
If the answer to this is "yes" then your router is responding (by booting into ROMmon) as "normal".  The router can't find a valid IOS therefore it goes into ROMmon.
Now if you want to load the IOS back, there are several ways of doing this.
1.  Eject the CF and copy the IOS from the PC into the CF;
2.  Boot the IOS from a supported USB thumb drive;
3.  TFTPdnld; or
4.  Xmodem
Your choice.
   with this above info-
 i came to know that "router need a ios only one time when router booting". when router found ios ,although any one deleted or problem in flash card, router never goes to rommon mode until i restart or power off
    thanks a lot for your replay.
Can you pleas mark this thread as "Answered"?
