3925 ISR G2 config issue
dasmith58
I have a new 3925 ISR G2 router with the universal IOS, 256kb flash in CF0, 1gb flash in CF1. When the router boots it prompts to enter initial config. Whether I say yes or no, enter the appropriate info, "write memory", and reload it comes up with a blank config. I've checked the config-register (2142), copied the startup-config to nvram:, flash0:, and flash1: but nothing works. Where am I going wrong? Thanks
gephelps
The problem is the config register. A setting of 0x2142 causes the router to ignore the startup-config. You should change the config register to 0x2102.
gephelps
That did it!
Thanks George
