3945e QoS
paaljakobsen
hi all,
we have a 3945e router and are about to set it production.
In the datasheet it says that :
* The Cisco 3900 Series enables deployment in high-speed WAN environments with concurrent services enabled up to 350 Mbps.
When we enable QoS, can we expect the performance/throughput to drop?
are QoS running in hardware/asic?
could not find any good reading on this...
regards,
Paal
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained  within this posting without consideration and with the reader's  understanding that there's no implied or expressed suitability or  fitness for any purpose. Information provided is for informational  purposes only and should not be construed as rendering professional  advice of any kind. Usage of this posting's information is solely at  reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever  (including, without limitation, damages for loss of use, data or  profit) arising out of the use or inability to use the posting's  information even if Author has been advised of the possibility of such  damage.
Posting
Yes, throughput might drop when QoS is enabled.
The 350 Mbps recommendation allows for "typical" QoS (and other services) configuration.
As far as I know, generally ISRs perform almost all service features using their main CPU.
